Thread: Goofy downshifting, particularly when cold
Results 1 to 2 of 2
  1. #1 Goofy downshifting, particularly when cold
    SE Level Member Ophidia's Avatar
    Nov 2010
    West Fargo, ND
    '04 GT non-S/C. This has been gradually getting worse.
    When the transmission is cold, it upshifts/downshifts fine. When it warms up, it tends to upshift very slowly on light throttle, and, when you're at a lower RPM in a gear and hit the gas a bit and it downshifts, it takes a very long time then almost seems to bang into gear. It's not the hard downshift feeling like when you step on it, more like a really slow shift then it just grabs and doesn't feel right. The car has 103,000 miles on it and I doubt it has had the tranny fluid changed. The level is good (actually a tiny bit high because I added some TransX, which had the expected lack of effect).
    Does this sound like something is wrong, or do I just need to drop the pan/change the filter?
    Thanks!
    2004 GT2 Leather, Sunroof, heated seats, other stuff, but only a little DIC. Also, Kawi Vulcan 2000 http://tinyurl.com/ophidia
  2. #2 Re: Goofy downshifting, particularly when cold
    I live here. TLSheff's Avatar
    Recommended tranny services are every $50,000 miles so your slightly overdue for one. I would start there and see how she shifts after that.
    Usually 1 filter and 7-8qts of Dex6
  1. Easy downshifting?
    By JESSEGOTTA GP GT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-06-2010, 05:25 PM
  2. Rear speakers acting goofy
    By kalikidd6600 in forum Audio, Security & Visual Electronics
    Last Post: 03-28-2010, 08:39 PM
  3. After CAI install got goofy on me!?!?!?
    By nikhackgt2 in forum General Tech Discussion
    Last Post: 02-23-2009, 02:00 AM
  4. Automatic Downshifting
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-23-2008, 08:12 PM
  5. Trans has a hard time downshifting when its cold?
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-28-2008, 10:38 AM
