Thread: Interior Lighting Issue
Results 1 to 5 of 5
  1. #1 Interior Lighting Issue
    SE Level Member RaiderGT's Avatar
    Maryland
    Hi guys,
    All the lights just went black on my air controls, radio, and DIC. The Dash lights still work fine. (No the dimmer switch is not in the low position). Any ideas on what might be causing this?
    Also the indicator light for my fog lamp switch wouldn't come on so I replaced that with a new switch and still no dice. Thoughts?
    In case it matters its a 2000 GT Canada spec car.
    Thanks
  2. #2 Re: Interior Lighting Issue
    Pennsylvania
    ...fuse?
  3. #3 Re: Interior Lighting Issue
    Maryland
    Fuses are good. Ive checked most of the basics. Before this i had a problem with the radio lights flickering and flashing random gang signs at me lol. But that I attributed to just the head-unit itself (on my 3rd one at $220 a pop). I read on a different post that a bad dimmer switch can cause something like this to happen but I dont think its that either.
  4. #4 Re: Interior Lighting Issue
    Dec 2011
    Detroit
    Quote Originally Posted by RaiderGT View Post
    Mine haven't exactly went out yet, but sometimes when I start my car all my lights around the radio (radio, fan control, etc) will go dark for a split second and come back on. But my dash lights and my hud display don't do it.
    Idk if im gonna end up in a similar situation to yours but the first step I would take would be to test for power and check bulbs. If it isn't that I would say check the dimmer switch.
    But maybe Im going in the completely wrong direction with this. Hope it helped tho.
  5. #5 Re: Interior Lighting Issue
    SE Level Member chuckd98gtp's Avatar
    Apr 2009
    Long Beach
    expieriencing the same thing, dic raidio ac, all dark. it comes and goes. when i move the dimmer switch dic gets brighter everything else darker... if you figured it out let me know
  1. New here--Interior Lighting Problem
    By msiscrm in forum Audio, Security & Visual Electronics
    Last Post: 10-08-2011, 06:42 PM
  2. Problem with interior lighting..
    By WolvesSoulZ in forum Audio, Security & Visual Electronics
    Last Post: 08-03-2011, 11:05 PM
  3. 04+ interior lighting question
    By jpdubrall84 in forum Audio, Security & Visual Electronics
    Last Post: 05-26-2011, 11:29 AM
  4. Help with lighting please
    By sinceregtp in forum Visual/Body Modifications
    Last Post: 04-15-2010, 10:59 PM
  5. How to change interior lighting
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 02-26-2010, 12:16 PM
