Thread: Which aeroforce functions does the 2000 GTP support?
Results 1 to 7 of 7
  1. #1 Re: Which aeroforce functions does the 2000 GTP support?
    Nov 2011
    S Fla
    As I look down the list, I see some interesting possibilities. The engine load function could really help with economy. Find what load your engine is most efficient at, then set cruise at that speed. In hilly areas with little traffic, turn off cruise and monitor engine load. Some of the guys at ecomodder have come up with load based cruise control systems. I wouldn't use them in traffic, but they're a great idea in some circumstances.
    I'm really looking forward to using the transmission slip function. I see my rpm stay steady while my speed rises, but have been told by one of the transmission sponsors that these transmissions sometimes do that up to 3000 rom or so. I certainly hope so, but I'd love to compare slippage rates at a given engine load with other members here.
    Obviously, the vacuum/boost function will be a great thing to have.
    It says it also measures inlet temps after the blower. Well, it says after the intercooler, but since I don't have one of those I'm assuming it measures after the blower. Looking forward to that.
    Injector pulsewidth and duty cycle. I'm not sure what the difference is. I would assume pulsewidth tells how long the injector is open, while duty cycle tells the percentage of time it is open vs the designed limits for it to remain open. Not sure, but looking forward to learning about it and putting it to use.
    I think the record function is going to be a huge help.
    And let's not forget the toys. 0-60, 1/4 mile, and horsepower.
    In short, what's taking Santa so long, anyhow? Shouldn't he have been here by now? Sleigh troubles? Maybe he should put an aeroforce on that thing.
    Black 2000 GTP. Replaced plugs, wires, maf, IAC, tires, tie rod ends, and s/c oil. Lifetime alignment. No mods yet, just got it. Straightening everything out first. 128,xxx miles
  2. #2 Re: Which aeroforce functions does the 2000 GTP support?
    The HP thing on the aero is a joke, not even close to what the real numbers are.
    It will measure inlet temps pre-blower, not after. So say its 70º going in and after the blower prolly 150º +. But you cant help that all because its a heaton blower. Only an intercooler can lower temps big time after blower.
    Ive never done the engine load one, but at freeway speeds you will prolly see when the car is running at 68ish mph the rpms will be at 1900-2000 and 30-32 ing. advance, thats when you would be at your best fuel economy at right around 30ish.
  1. Overhead engine support
    By Phyrstorm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2011, 01:59 PM
  2. lumbar support
    By vincegpking in forum General Tech Discussion
    Last Post: 04-07-2011, 06:44 AM
  3. HELP! radiator support replacement
    By 04BlackComp_G in forum General Tech Discussion
    Last Post: 03-22-2011, 07:42 AM
  4. Needs some GPF support and votes!
    By Swash in forum Off Topic Discussion
    Last Post: 10-07-2010, 02:58 PM
  5. 2-support Mirrors
    By arc in forum 04+ Specifics
    Last Post: 02-08-2010, 02:42 PM
