Thread: 2007 GT - A few questions: Driveline, Tranny
Results 1 to 4 of 4
  1. #1 2007 GT - A few questions: Driveline, Tranny
    GT Level Member RotyP's Avatar
    Tn
    So, my buddy and I changed the plugs in my car last weekend. We moved the dog bones out and rolled the engine forward to do the change. After and during the change a few things happened that I noticed. One is that tranny lines started leaking during the change. The one going straight up into the tranny was actually dripping pretty good during the change but has seemed to stop mostly. I noticed it was a bit wet today when I crawled underneath it the car. I am assuming its the O rings but i have not pulled them out to see if the fittings got damaged when we rolled the engine.
    My second issue is that one morning after the change I went out and started the car up to leave. I put it in reverse and noticed a thunk going into reverse from park and then from reverse to a forward gear. Same thing from a forward gear to reverse. So I put the car up on some rhino ramps and had my girlfriend run it through the gears while i was under it. I thought for sure it was a mount but the noise does not appear at all to be coming from the mount. I noticed that(and i could be wrong) but when I heard it the driver side axle moved a bit and the noise seemed to come from that area of the axle going into the transmission.
    Any ideas? its 2007 with all original parts except and almost 91k miles.
    2007 Grand Prix GT - 20% Tint, Red Inlays
  2. #2 Re: 2007 GT - A few questions: Driveline, Tranny
    Portland Oregon
    Could be time for new axles. The axles have a tendency to move a bit when load is applied though. Try tightening the dog bones more. I left one bolt kind of loose once and it made the noise you're describing
  3. #3 Re: 2007 GT - A few questions: Driveline, Tranny
    Tn
    The dog bones are tight I'm pretty sure. I will check them to be safe. Does anyone know of anything in that area that would allow the axles to move enough to make noise? I may actually still be under my powertrain warranty. Gonna check the build dates of the car.
  4. #4 Re: 2007 GT - A few questions: Driveline, Tranny
    Tn
    So, the powertrain warranty for the car does not run out till the 12th of this month. I took it to a stealership and so far the mounts and axles are good. I told them before I left it I had checked the mounts and they appeared good but I understand they have their process to go by. They think its in the transmission or something and will need more investigaton. It has to spend the night there so they can look at it more tomorrow.
  1. A few questions about 2007 Remote Start
    By krpiper in forum Audio, Security & Visual Electronics
    Last Post: 02-24-2017, 11:45 AM
  2. 2007 GT first car.
    By ragedsparrow in forum Introductions/Noob Questions
    Last Post: 06-17-2011, 12:50 PM
  3. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  4. driveline vibration issue
    By nutcase in forum Off Topic Discussion
    Last Post: 01-14-2009, 03:05 AM
  5. Driveline Growl
    By Mr Book in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-15-2008, 02:07 AM
