well i took a test light and unhooked the motor and found no power at the motor. but the switch has the back and forth motions and then it will lean the seat back and forth motion it will do that. so your thinking its the switch? there is absolutly no noise coming from the motor at all. i tried to tap it with a ratchet and still nothing........ hope its a easy fix thanks
