Thread: Can you hook up relays to stock bulbs?
Results 1 to 19 of 19
  1. #1 Can you hook up relays to stock bulbs?
    May 2011
    wisconsin
    I want to hook up a relay to my lows highs and fogs that way I always have bright lights. I have a big system and despite having a huge red top battery and a 50 farad stinger cap my lights still dim a little. If you can hook up relays to stock bulbs please tell me how. Thank you very much. Oh yeah another reason I want relays is so my drl will be off, thanks again.
  2. #2 Re: Can you hook up relays to stock bulbs?
    May 2011
    wisconsin
    Quote Originally Posted by szalajka05 View Post
  3. #3 Re: Can you hook up relays to stock bulbs?
    Jun 2011
    Detroit, MI
    It wouldn't do anything. Get HID's and a relay, much brighter.
    iLoveSpade
  4. #4 Re: Can you hook up relays to stock bulbs?
    Quote Originally Posted by Hippo Machine View Post
    Andddd, they pull more power from the battery so he is back to square one.
  5. #5 Re: Can you hook up relays to stock bulbs?
    Jun 2011
    Detroit, MI
    Then get a better alt, don't get a hid relay harness for stock lights.
    iLoveSpade
  6. #6 Re: Can you hook up relays to stock bulbs?
    Sep 2011
    Arkansas
    The cap really isn't going to help a great deal. Honestly, in the case of a "big system", an H.O. alternator may be your best bet. No need to go very expensive, depending on how "big" your system is... check out powerbastards for some decent alts. There's also a conversion kit that allows CS144 large-case GM alts bolt up to 3.8L engines. I'm not sure about hood clearance as I've never used it personally, but I thought I'd mention it. An upgraded alternator is definitely your best bet.
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  7. #7 Re: Can you hook up relays to stock bulbs?
    Sep 2011
    Arkansas
    Yeah, but they don't dim. It won't fix his voltage drop (which is why his lights are dimming), but it will take care of the issue which he seems to have a problem with.
  8. #8 Re: Can you hook up relays to stock bulbs?
    May 2008
    Winnipeg, MB
    Quote Originally Posted by Fatboy501 View Post
    conversion kit????
    I have a cs144 alternator for sale,
    2007 Pontiac Grand Prix
  9. #9 Re: Can you hook up relays to stock bulbs?
    May 2011
    wisconsin
    The main reason I want to hook up a relay to my stock low beams is to disable my drl. so can you hook up a relay like the ones people hook up for hids to regular bulbs?
  10. #10 Re: Can you hook up relays to stock bulbs?
    SWPA
    I'd ditch the cap. It doesn't help your dimming issues and puts a larger strain on your charging system.
  11. #11 Re: Can you hook up relays to stock bulbs?
    May 2011
    wisconsin
    Hell no lol its for my system! I tried my system without it and kmy lights almost went off... Now there barely dim but they do dim a little thats why I want to know if you can hook a relay up.
  12. #12 Re: Can you hook up relays to stock bulbs?
    May 2008
    Winnipeg, MB
    the rest of your cars electrical system is suffering too so get more power to it somehow
  13. #13 Re: Can you hook up relays to stock bulbs?
    May 2011
    wisconsin
    Quote Originally Posted by tod1d View Post
    In need of a high output alternator
  14. #14 Re: Can you hook up relays to stock bulbs?
    May 2008
    Winnipeg, MB
    fatboy501 mentioned that the alternator I can sell you will work with some minor conversion work
  15. #15 Re: Can you hook up relays to stock bulbs?
    Sep 2011
    Arkansas
    Chevy 3100, 3400, 3500, 3800 and 3900 Alternator Upgrade This product will allow you to mount a CS144 alternator. However, I have no clue about hood clearance after this has been done... whether you try it or not is up to you. In my opinion, if you're on a budget, High Output Alternators and Accessories | PowerBastards.com has about the best deal for solid (from what I've read) alternators with decent customer service.
  16. #16 Re: Can you hook up relays to stock bulbs?
    Nov 2011
    NY
    If you're running components that require a 50f Capacitor then I would say you're probably taxing your electrical system just a bit and the HO Alt. is not going to hurt. You've obviously spent some cash on the stuff, it just might require a little more.
    Have you load calculated your current/power draw from all you have installed, including the lights? Although I think the lights are the least of your worries unless your dimming only happens when you have the lights on. Without really knowing what kind of power you need at full load we're all only guessing here.
    Lol... Have you considered a LARGER Cap? hahahaha, that boggles my mind to need something so big but they DO make them. The HO Alt. with 2nd battery set-up, larger cap might be what's needed here, isolating power to the added components on their own power grid!
    Just my $.02
    I forgot to answer your question...
    Yes, relays can be added if that's what you want to do.
    The relay's act as switches, controlling the power going out to the device you want to turn on/off. The power line that is controlled by the relay can be from either the stock wiring or what is better is taking the power direct from the battery or fuse block. There are some set up's I've read and it is all a bit involved to do it right but not difficult as long as you do your homework first, lol.
    Check this out... might help some...
    http://www.backinblackgp.com/
  17. #17 Re: Can you hook up relays to stock bulbs?
    GTP Level Member
    Nov 2011
    Kansas
    Run another battery, bigger wires, better alternator and lose the cap.
  18. #18 Re: Can you hook up relays to stock bulbs?
    May 2011
    wisconsin
    Quote Originally Posted by develand View Post
    Zero gauge wires installed
    Red top optima battery installed
    HO alt on the way
    Second red top on the way
  19. #19 Re: Can you hook up relays to stock bulbs?
    SWPA
    Go with yellow top, or even better a blue top.
  1. Does anyone know the Wattage draw of the Stock headlight Bulbs?
    By Blacknight02GT in forum Off Topic Discussion
    Last Post: 06-26-2009, 11:33 AM
  2. how do you hook up subs with stock head unit?
    By peej1108 in forum Audio, Security & Visual Electronics
    Last Post: 05-30-2009, 04:57 AM
  3. Electrical Gurus step in (relays)
    By Toofastgs in forum Audio, Security & Visual Electronics
    Last Post: 03-11-2009, 10:30 AM
