Thread: what do i need.. for a 13.5 second car
Page 3 of 3 FirstFirst 123
Results 41 to 50 of 50
  1. #41 Re: what do i need.. for a 13.5 second car
    Waukesha, WI
    if you drive like a normal person your tranny will be fine on a 3.4, if you drive like a re re then yea say bye to your tranny
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  2. #42 Re: what do i need.. for a 13.5 second car
    This thread is too long for the question.
    Theres a million different ways to get there.
    Traction would be your best bet.
    Guy did bolt ons and slicks and resulted in 13.67 or something around there.
    On a 3.8 pulley.
  3. #43 Re: what do i need.. for a 13.5 second car
    Out West
    Quote Originally Posted by redlinepontiac View Post
    I was going to add that the first transmission wasn't actually dead when i had it built. Flexplate cracked and it wasn't but $2,000 to get a built trans with upgrades AND the flexplate replaced vs $600 for just the flexplate replaced.
    The stock trans was worn pretty badly. Clutches were charred, Input/output was missing a tooth here and there, 4th gear had half the splines missing.
    The 2nd and 3rd were rebuilds of the built trans, TQ converter **** the bed the first rebuild, Channel plate gasket and another i can't quite remember went the 2nd time and car was losing 2qt/day in trans fluid, which made the tq converter **** the bed again.
    4th trans is a charm though, added a trans cooler on the 1st rebuild of the built trans.
    2-3 times daily 1-2nd gear WOT and we're still cookin'
  4. #44 Re: what do i need.. for a 13.5 second car
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Quote Originally Posted by GTPSHAWTY View Post
    everyone knows my last gp was stolen... but recently i came across another gtp with a decent motor 170 xxx plus miles... but im really looking to take it out and rebuild it completely.. cam heads and so on.. what good combo would be a good way to make a mid to low 13 second car...
    Mods in my sig.
  5. #45 Re: what do i need.. for a 13.5 second car
    Quote Originally Posted by boostedcompg View Post
    Dude if your not wanting to drop the coin you have no buisness modding. Point blank
    Every bit of this.
    Whatever you do to the car...if you don't have double, or sometimes triple what your putting into mods, then you shouldn't really tearing into it...because when you spend $200, you end up spending $300+...
  6. #46 Re: what do i need.. for a 13.5 second car
    On a 3.8 pulley.
    Headers, Intake, Tune...3.8"
    Slicks.
    13.6 @ 99.
    Also, if that car had rockers and a 3.4"...lol, 13 flat?
    I ran 13.8 @ 99 with PEM's/3" DP & Exhaust/3.5"/1.84 Rollers...but on street tires and no tunez...
  7. #47 Re: what do i need.. for a 13.5 second car
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    all it took for my first 13.5x was headers, intake,1.9 YT's, 3.4, UD pulleys and slicks. about $700. did it at 102 mph.
  8. #48 Re: what do i need.. for a 13.5 second car
    GTP Level Member
    Nov 2008
    MA
    cant do rockers and a cam. one or the other
    ofcourse you can.. 1.7 ratio rollers with a nice cam would be a sweet setup..theres obvs better alternatives that make more power just saying
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  9. #49 Re: what do i need.. for a 13.5 second car
    Quote Originally Posted by JDrach View Post
    Well i'm not sure how else i'd tune the PCM besides getting the 1.0 from ZZP...
    Where do you live in IN? Check out PRJ he's around Indy iirc
  10. #50 Re: what do i need.. for a 13.5 second car
    Pretty sure the OP was thinking of running the 1.9's or 1.95's with a cam.
    Granted, I'm sure you could do that on a VS, XP, or S1X...but OMG, lift.
