Thread: Trying to sell me a P.O.S?? Help!!
Results 1 to 14 of 14
  1. #1 Trying to sell me a P.O.S?? Help!!
    Nov 2011
    Test drove a 2003 Pontiac Grand prix without overdrive tonight and at 60mph the car was running 3000 rpm. I even sped up to 65 and wasit doing like 3300rpmI and it would still not up shift?? Am I losing my mind here cuz I don't think that's right! It has 74000 miles.
  2. #2 Re: Trying to sell me a P.O.S?? Help!!
    Out West
    It has an aggressive tune is all
    No seriously. Whatever their price is, knock off 3-4k because 4th gear is gone on it.
  3. #3 Re: Trying to sell me a P.O.S?? Help!!
    The 03 should have the hardened 4th gear but some i don't think do. It's a common problem on them.
  4. #4 Re: Trying to sell me a P.O.S?? Help!!
    Omaha, NE
    ^This.
    Overdrive is 4th gear, without Overdrive/4th you only have 3 gears, so RPMs will be high.
  5. #5 Re: Trying to sell me a P.O.S?? Help!!
    Jul 2011
    NW Ohio, USA
    Uhh yea, I'd say something isn't quite right. I know that the switch to OD is temperature related (or is that TC lockup? :scratch: ) but I'd definitely say that if it was in "D" and it wouldn't shift something is definitely fubared up.
    I Gotz Moar Powar Than U Gotz
    The HWG Thread = Winning.
  6. #6 Re: Trying to sell me a P.O.S?? Help!!
    Waukesha, WI
    3rd gear would be about 3k rpms at 60 65ish.
    depends on the build date of the car, early 03s i believe didnt have the hardend 4th hub, mid to late should have it for sure. i think
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  7. #7 Re: Trying to sell me a P.O.S?? Help!!
    Never Never Land
    TC lockup is temp sensitive. Crusing at 55 when the car is cold it stays at about 1900 RPMS....once it gets to 165 it drops to like 1600ish so that must be the temp lock up activates.
  8. #8 Re: Trying to sell me a P.O.S?? Help!!
    Mercer, Pa
    My 03 had soft 4th shaft but didn't fail. I replaced it with the rebuild at 165k. Does it have any codes?
  9. #9 Re: Trying to sell me a P.O.S?? Help!!
    Minnesota
    Quote Originally Posted by Oxner View Post
    If I know one thing about buying a car it is this:
    If you have a bad feeling about it don't buy it. It's not like there is a shortage of cars around. lol Keep looking.
  10. #10 Re: Trying to sell me a P.O.S?? Help!!
    Oct 2011
    Chicago area
    I don't know what y'all are talking about temp related. My 2002 GTP shifted into OD or 4th in any temp. I think you need to find the solinod that shifts third to fourth and have it tested.
  11. #11 Re: Trying to sell me a P.O.S?? Help!!
    I've seen a couple of 2003's that were produced late 2002 with non hardened 4th gear hub shafts.
    Likely the shaft is stripped and that's why there's no 4th.
    Poncherelli... I think they are talking transmission fluid temperature. There IIRC is a temp at which the trans defaults to 3rd gear in an effort to have you drive slower and get it's heat back down.
  12. #12 Re: Trying to sell me a P.O.S?? Help!!
    Jul 2011
    NW Ohio, USA
    I was mistaken on the switch to 4th gear being temp related. It actually controls TC lockup which according to 4thGen occurs at 165* (engine temp). As far as the switch between 3rd and 4th though I don't believe there to be any temp sensor that says one gear or the other (unless we are talking about what Bill mentioned in his post).
  13. #13 Re: Trying to sell me a P.O.S?? Help!!
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    My 2000 GT lost its overdrive shortly before i traded it in, would just stick in 3rd gear.
  14. #14 Re: Trying to sell me a P.O.S?? Help!!
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    My 2000 GT lost 4th too... Bought it with high miles but they were all highway(4th) so go figure. Just talk them down 3k cause the trans needs rebuilt then have TEP build/install you one with the money you saved and you'll have the piece of mind of a bulletproof tranny
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  1. Why did I sell her? :(
    By cameron92 in forum Off Topic Discussion
    Last Post: 09-10-2011, 08:07 AM
  2. This is how you sell a car!
    By MBruneaux in forum Off Topic Discussion
    Last Post: 02-05-2011, 06:46 PM
  3. Keep or sell the GTP?
    By Drew86maro in forum Off Topic Discussion
    Last Post: 02-04-2011, 05:56 PM
  4. Sell the GTP or not? What would you do?
    By Lawngoose in forum Off Topic Discussion
    Last Post: 07-04-2009, 04:54 AM
