Thread: Cooling fans contanly running
Results 1 to 5 of 5
  1. #1 Cooling fans contanly running
    SE Level Member Heavy Metal's Avatar
    Jan 2012
    Toronto Ont, Canada
    Okay so my cooling fans are contantly running. as soon as i strat the car they start and they don't turn off until i shut the car off. I have already replaced the temp sensor, the thremostat, and the reley, hoping that it would slove my problem but still no luck i have no idea what else it could be at this point and am hoping that someone here can help me out.
    also the car is a 2000 grand prix Se 3.1 motor
    thanks in advance
  2. #2 Re: Cooling fans contanly running
    St. Louis
    Give this thread a read and see if it's similar to your issue.
    http://www.grandprixforums.net/cooli...elp-69095.html
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    If your check engine light is on the fans will stay on all the time.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  4. #4 Re: Cooling fans contanly running
    Jan 2012
    Toronto Ont, Canada
    I have no check engine lights on or any warning lights on. also defrost and AC are both off and the fans still run. i also noticed that there is a sensor on my rad (i assume a level sensor) could this be the problem? does anyone now how to check if that sensor is working? (resistance value for sensor) i don't want to have to change it if i don't have to (i can't afford to keep replacing parts that are fine) or if you can even change it or do you have to change the whole rad?
  5. #5 Re: Cooling fans contanly running
    Quote Originally Posted by Sushamouf View Post
    This is only true for a few codes. You can have a check engine light w/o the fans coming on.
  1. cooling fans
    By polarisdescent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-07-2012, 04:28 PM
  2. cooling fans on 90 G.P.
    By TIMS TURBO in forum General Tech Discussion
    Last Post: 05-01-2012, 06:34 AM
  3. cooling fans always run
    By jaxso6 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-25-2011, 08:33 PM
  4. HELP! cooling fans not running
    By nauss in forum General Tech Discussion
    Last Post: 09-15-2011, 02:20 PM
  5. cooling fans not running and overheating.
    By gtp40th in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2010, 07:46 PM
