Thread: Which size air intake filter do i need?
Results 1 to 6 of 6
  1. #1 Which size air intake filter do i need?
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    I need a new air filter for my intake, bad but i don't know what the right size is. I'm saying this cause right now i can take the actual filter of my intake and rotate it 360º around. Then, when i unhook everything it was almost impossible to fit back into the black rubber surrounding it. I'm sorry if i cant explain myself good. My intake looks like this:
  2. #2 Re: Which size air intake filter do i need?
    Oct 2011
    Toledo, OH
    Looks like a 9inch cone to me.
    7"
  3. #3 Re: Which size air intake filter do i need?
    Oct 2011
    New Jersey
  4. #4 Re: Which size air intake filter do i need?
    Oct 2011
    Toledo, OH
    Spectre has different inserts to fit whatever size tube you have. If you are gonna get one, just go to Autozone and take your filter off in the lot and take it in to compare.
    7"
  5. #5 Re: Which size air intake filter do i need?
    measure the OD of the pipe you have.
    measure the ID of the filter you have.
  6. #6 Re: Which size air intake filter do i need?
    Jersey
    step 1- throw out what you have
    step 2- buy a 3-1/2'' silicone adapter to 4''
    step 3- go to pep boys and buy a 4'' 22* sweep
    step 5- buy a spectre cone filter
    step 6- put together and you will have something that looks decent for about $40.00
    16' wrx sti- stock
  1. intake filter question
    By mcsddd in forum General Tech Discussion
    Last Post: 08-23-2010, 06:22 PM
  2. cone filter size
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-12-2009, 12:51 AM
  3. what size wrenches for fuel filter on a 02 GTP?
    By shaferz in forum General Tech Discussion
    Last Post: 05-27-2009, 12:57 PM
  4. what size filter for the wizard CAI
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-17-2008, 01:21 AM
