Thread: 2000 GTP Quit, Need help!
Results 1 to 4 of 4
  1. #1 Re: 2000 GTP Quit, Need help!
    Saraland Alabama
    hows the coolant and oil? White smoke is usually water/coolant. Also it's one of my pet peeves, but cranks and turns over are the same thing, meaning the engine turns (sorry just bugs me) if 1 injector is stuck open it would flood. Disable the fuel pump, and see if you can get it to start with starting fluid
  2. #2 Re: 2000 GTP Quit, Need help!
    Jan 1970
    Maquoketa, Iowa
    Fluids are fine, I call it cranking when it doesn't do anything but crank, Turning over for me means that it starts but dies right away... lol
    They were working on it before I came there, so they cranked it testing fuel a ****load of times, after replacing pumps and such, killed the battery. We were thinking along the lines of an injector being open but why wouldn't it make a putter or start? And if it was an injector stuck open, it has to be flooded by now...
  1. HID's quit working. any ideas?
    By mwalk00gtp in forum General Tech Discussion
    Last Post: 12-08-2008, 03:17 PM
  2. 2000 se
    By evilpacker in forum Visual/Body Modifications
    Last Post: 07-18-2008, 08:10 PM
  3. 2000 Pontiac SE :)
    By 2000segp in forum Introductions/Noob Questions
    Last Post: 06-20-2008, 11:07 AM
  4. About 2000 GT!! New at this...
    By down_tap in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-21-2008, 07:55 AM
