Thread: ok heres another noise issue.is it the hood?
Results 1 to 8 of 8
  1. #1 ok heres another noise issue.is it the hood?
    GT Level Member spider4's Avatar
    Nov 2011
    portsmouth,virginia
    well i know that as cars get older they start to creak and groan more.most people say just gotta live with it.i tend to think that even noises can be fixed.i also know that if i had pictures and video it will help more..im working on that.anyway this noise seems to come from under the hood,but you only hear it when you are in drive and stopped with foot on brake.it sounds like a heavy vibration being transfered throughout the car,driver door vibrates.its also rather loud.but as soon as you hit the gas and go all is normal and the loudness and vibration disappears until you stop again at a light or something.if you put in park or even reverse hardly noticeable.also i have noticed that if i am in drive and stopped and i pop the hood most of the noise goes away,so is it my hood.ive also noticed that the hood doesnt seem to line up completely flush with the front end.also while we are on the front end,my friend whom does mechanic work says these pontiacs are notorious for becoming not so tight and loosing clips and such.what should i do?have you experienced this?
  2. #2 Re: ok heres another noise issue.is it the hood?
    check you exhaust hangers to see it they are missing.
  3. #3 Re: ok heres another noise issue.is it the hood?
    Nov 2011
    portsmouth,virginia
    yeah.that ive checked already.all hangers good.
  4. #4 Re: ok heres another noise issue.is it the hood?
    motor and trans mounts ok?
    i had some vibrations in gear when my motor mount was blow to chit.
  5. #5 Re: ok heres another noise issue.is it the hood?
    Nov 2011
    portsmouth,virginia
    ok im not too mechanical.i know that there are two visible motor mounts on top.they seem pretty solid.i know there are also some on bottom.what should i look for.trans mounts have not checked,so possibly.http://i1095.photobucket.com/albums/...78761177_o.jpg
  6. #6 Re: ok heres another noise issue.is it the hood?
    this is the how to for the engine mount, http://www.grandprixforums.net/engine_mount.php the trans mount is on the other side and easier to change, not that the motor mount is all that hard to do.
    and this is what a bad trans mount looks like and how to change it too. look for part 2 Buick Regal Transmission mount pt.1 - YouTube
    i just did both, took less than 2 hours to change.
    pop your hood and watch the engine as you shift it from park to drive, then to reverse, see if the engine is moving A LOT, if so the mounts are bad.
  7. #7 Re: ok heres another noise issue.is it the hood?
    Nov 2011
    portsmouth,virginia
    ok cool,i think i can do this.thanks so much.this car does have 210k miles on it,and looks like the previous owner didnt do any maintainence.
  8. #8 Re: ok heres another noise issue.is it the hood?
    Nov 2011
    portsmouth,virginia
    MOV01274.mp4 video by hulkman41 - Photobucket scotty this is a little video of how it sounds when its in drive and stopped.the sound quality is not great,but if you can really hear it will sound like a steady pounding vibration coming from the engine area.it causes the door and dash to vibrate too,so youve got to block that out.and trust if you do hear it,its 10x louder.but only when in drive and stopped.if you pop the hood the noise is not as bad or if you are in park,reverse,or driving not as bad.so leads me to think that something under hood is rubbing on hood or wheel well area and sending that vibration,pounding sound.
  1. squealing noise from crank pulley area? PCV issue?
    By neel2008 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2013, 02:14 PM
  2. Intercooler clearance issue! Cut the hood or take out spacers?
    By copgtp in forum General Tech Discussion
    Last Post: 07-23-2012, 09:28 AM
  3. Ugh I hope this is no one on heres
    By tayl5645 in forum The Rant Forum
    Last Post: 07-08-2011, 06:29 AM
  4. Idling noise under the hood
    By ed419 in forum General Tech Discussion
    Last Post: 04-20-2010, 02:07 PM
  5. heres my car
    By blazedgp in forum Visual/Body Modifications
    Last Post: 02-10-2008, 11:37 PM
