Thread: key stuck in ignition
Results 1 to 5 of 5
  1. #1 key stuck in ignition
    Nov 2011
    St. Louis
    i got an 01 gp and the key won't come out of the ignition i got it out putting a pen thru the hole under the dash but my question was what part do i need to replace to fix this is it a part i can buy at an auto parts store or should i go to a junkyard for it thanks all
  2. #2 Re: key stuck in ignition
    take that little cover off the bottom of the column and super glue that little white tab/button up and never worry again.
  3. #3 Re: key stuck in ignition
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    SEARCH option works good!!
    http://www.grandprixforums.net/key-s...nder-7824.html
    I had this same problem a while back and simply took the white plastic part out and threw in trash.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  4. #4 Re: key stuck in ignition
    Ocala, FL
    Check your btsi fuse and see if it's blown.
  5. #5 Re: key stuck in ignition
    SE Level Member Summer Time Anytime's Avatar
    Aug 2011
    A-Town, SD
    If you don't get it to work try shifting when the car is off all the way back then forward again. It works every time that rare occurance happens to my car.
  1. Key stuck in the ignition
    By Gearhead Garland in forum General Tech Discussion
    Last Post: 01-31-2012, 06:32 PM
  2. KEy stuck in ignition
    By EJRJR91 in forum Audio, Security & Visual Electronics
    Last Post: 02-20-2011, 10:42 PM
  3. Key stuck in ignition.
    By at2smithjason in forum General Tech Discussion
    Last Post: 03-31-2010, 06:16 PM
  4. key stuck in ignition?
    By jaketrey32 in forum General Tech Discussion
    Last Post: 05-15-2009, 05:28 PM
  5. Key stuck in ignition
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-08-2008, 06:36 PM
