Thread: Blower motor intermittent help!! its cold in ak
Results 1 to 6 of 6
  1. #1 Blower motor intermittent help!! its cold in ak
    SE Level Member ttjj1410's Avatar
    Nov 2011
    fairbanks, ak
    Hello. So i have been having this issue with my blower motor since i moved to alaska from georgia. when i start the car and turn on the blower(for heat) it screams for a sec then stops. other times it wont come on unless i gently bang on the glove box or top of dash. it has no problems turning off. also when it is running it will speed up and slow down as if someone is controlling the voltage with a dimmer switch. i am pretty mechanically inclined and very familiar with elecricity. i dont believe it to be a short or the a/c control box. any other help is very appreciated.
  2. #2 Re: Blower motor intermittent help!! its cold in ak
    time for a new fan motor.
    they get wet, damp or just old and take a dump on ya.
  3. #3 Re: Blower motor intermittent help!! its cold in ak
    Nov 2011
    fairbanks, ak
    yea i was leaning in that direction. i have tried everything up to and including re-programming the computer it helped for a week the back to the same old same old.
  4. #4 Re: Blower motor intermittent help!! its cold in ak
    you could try to lube the old motor by spraying it with some wd-40, it may help you out till you get a new or used one, they are for sale used, check ebay, or morads, used is like 40 bucks i think. comes with the whole motor and fan.
  5. #5 Re: Blower motor intermittent help!! its cold in ak
    Nov 2011
    fairbanks, ak
    got a new one on the way thanks so much for youre advice
  6. #6 Re: Blower motor intermittent help!! its cold in ak
    Dec 2011
    concordia
    sounds like a blower resistor from my research
  1. Intermittent HVAC blower
    By Doc Banger in forum General Tech Discussion
    Last Post: 01-26-2011, 11:37 AM
  2. Blower motor doesn't turn on - no signal to blower control module?
    By Joe942 in forum General Tech Discussion
    Last Post: 01-17-2011, 06:12 PM
  3. Intermittent Blower Motor
    By Securu99 in forum General Tech Discussion
    Last Post: 06-20-2010, 12:21 PM
  4. Blower motor OR blower motor resistor
    By DDK in forum General Tech Discussion
    Last Post: 06-01-2010, 07:38 AM
  5. blower motor inactive in extreme cold.
    By schreurs1 in forum General Tech Discussion
    Last Post: 01-16-2009, 12:43 PM
