Thread: exhaust on a 2004 grand prix
Results 1 to 20 of 27
  1. #1 exhaust on a 2004 grand prix
    SE Level Member alloutgandprix04's Avatar
    Oct 2011
    Sobieski, Wisconsin, United States
    i have a 2004 grand prix gt 3.8 v6 already has stock dual exhuast but i was thinking of doing dual flowmaster 40 or 44's i was wondering if anyone has done it and if it sounds good or if anyone has any different exhuast setup that sounds good.
  2. #2 Re: exhuast on a 2004 grand prix
    Omaha, NE
    Headers, Glasspack where the resonator is, stock everything else is what sounds the best.
  3. #3 Re: exhuast on a 2004 grand prix
    Banned
    Aug 2011
    spartanburg sc
    i took the exhaust manifold off a 4.3 chevy vortec welded the old holes closed had new holes drilled match the heads of a 3.8 series 3 rn the exhast the same route ct open the conveter with a plasma torch removed the insides welded it back so now its a wide spot in the pipe no guts run dual from the converter back installed maga flow mufflers now when i crank up in the mornings im the nieghborhood alarm clock kicked it to the floor at 80 with a g force chip and it screams like the devil is under my hood as i bury a 140 speedo have video on my cell phone busting a ****** in crwn vic with big wheels from 80 to way past 140 really hurts pretty punks feelings in thier 305 horse mustangs general motors *****es play with it but u cant **** with it oohh i got the heads not shaved but slaughtered and a schiender racing cam and some other dirtyed up parts thats how we do it in spartanbrg south carolina that my friends is whats up
  4. #4 Re: exhuast on a 2004 grand prix
    Omaha, NE
    Quote Originally Posted by timothy d gosnell View Post
    is this jibberish?
    BRANDON! I need one dem duur down souf interpritationers!
  5. #5 Re: exhuast on a 2004 grand prix
    what!?
    you give the carolinas a bad name
    SMGPFC Member #10
  6. #6 Re: exhuast on a 2004 grand prix
    slow down...
    you lost me at not buying headers or a plog.
  7. #7 Re: exhuast on a 2004 grand prix
    Also going to have to request a dyno sheet on 330 HP without a power adder on a 3.8
    http://dormanproducts.com/p-12166-67...t%2520Manifold
    That would never fit a series II+ 3800.
    Unless you cut and reweld it. But you said you had the holes filled and re-drilled.
  8. #8 Re: exhuast on a 2004 grand prix
    Omaha, NE
    4.3 Manifolds
    1-2------3
    3.8 Manifolds
    1--2--3
    There's no way that would fit without SERIOUS modification.
  9. #9 Re: exhuast on a 2004 grand prix
    Jun 2011
    Detroit, MI
    4.3 Manifolds
    1-2------3
    3.8 Manifolds
    1--2--3
    Yea, not worth it lol
    iLoveSpade
  10. #10 Re: exhaust on a 2004 grand prix
    flowmasters = drone city.
  11. #11 Re: exhaust on a 2004 grand prix
    Banned
    Aug 2011
    spartanburg sc
    dad was a welding instructor for 25 years for southern railroad has his own welding fab shop now say what u want have the video of tit shifting into overdrive at 110 and pulls all the way till i get out of at 140 so while you guys ride down the road against the speed limiter at what a mmeasley120 or 125 im saying later at at 140 plus and for the smart ass that tthinks the firing order matters once the gas is ignited and pushed out the exhaust valve it doesn't know **** same with long tube headers all the tubes are the same size bolt on to a 350 or 305 or a 327 all have different firing orders but yet they work as well on one as the other turn your 3.8 5500 ill shift mine into second around 6800 or 72p0 if im feeling pissed have turned it as high as 7500 but i was in neutral at a red-light while my baby gave me road head brother has a 97 -28 lt1 6 speed i will run off and hide from him you guys with stock motors taiwan mufflers on mine i took the resonator off mine i put custom wheels on mine mine is completely stock except for the drive train all that custom **** don't get it when the light turns greens
  12. #12 Re: exhaust on a 2004 grand prix
    um, what the french toast are you talking about sir?
  13. #13 Re: exhaust on a 2004 grand prix
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    dad was a welding instructor for 25 years for southern railroad has his own welding fab shop now say what u want have the video of itt shifting into overdrive at 110 and pulls all the way till i get out of at 140 so while you guys ride down the road against the speed limiter at what a mmeasley120 or 125 im saying later at at 140 plus and for the smart ass that tthinks the firing order matters once the gas is ignited and pushed out the exhauuste valve it doesnt know **** same with long tube headers all the tubes are the same size bolt on to a 350 or 305 or a 327 all have different firing orders but yet they work as well on one as the other turn your 3.8 5500 ill shift mine into second around 6800 or 72p0 if im feeling pissed have turned it as high as 7500 but i was in nuetral at a redlight while my baby gave me road head brother has a 97 -28 lt1 6 speed i will run off and hide from him you guys with stock motors iwant mufflers on mine i took the resonator off mine i put custom wheels on mine mine is completely stock except for the drive train all that custom **** dont get it when the light turns greens
    Yeah I did the same thing didn't check twice mine goes really fast got a friend with a 77 vega awd can't touch me then i took it to the strip was barely hooking up in the back 1/8th so i put on softer winter tires now i can get the grip but i hear oldsmobile has a new v8 coming out that will be nasty as a bucket of chicken
  14. #14 Re: exhaust on a 2004 grand prix
    utah
    Flowmaster 40's sound like poo...just listen to mine
  15. #15 Re: exhaust on a 2004 grand prix
    Kansas
    I've had super 44s and 28" glasspack.... sounds good at idle... 2000+ sounds like a v6 w/ hella drone.
  16. #16 Re: exhaust on a 2004 grand prix
    Don't do that again.
    Those who are guilty know what I'm talking about.
    Also, new guy: Get us a dyno slip or a time slip.
  17. #17 Re: exhaust on a 2004 grand prix
    ^^that or pics?
    SMGPFC Member #10
  18. #18 Re: exhaust on a 2004 grand prix
    timothy d gosnell
    Banned
    Anyways...
  19. #19 Re: exhaust on a 2004 grand prix
    why banned?,
    i wanted to see what he was gonna say next
    SMGPFC Member #10
  20. #20 Re: exhaust on a 2004 grand prix
  1. 2004 Grand Prix >>
    By eraser in forum General Tech Discussion
    Last Post: 07-12-2011, 11:35 AM
  2. 97-03 Grand Prix Exhaust on 2004-up
    By 04montess in forum General Tech Discussion
    Last Post: 03-29-2011, 01:22 PM
  3. 2004 Grand Prix
    By freightliner009 in forum General Tech Discussion
    Last Post: 03-07-2011, 01:49 AM
  4. 2004 pontiac grand grand prix gtp
    By jeffreytatro606 in forum Introductions/Noob Questions
    Last Post: 02-03-2011, 06:23 PM
  5. Exhaust on 2004 grand prix gt???
    By zewski in forum Introductions/Noob Questions
    Last Post: 09-27-2009, 11:08 PM
