was driving home last night and thought about making a video - instead i ended up hitting about 120mph and my power steering went out and my car began missing if trying to accelerate. Wasnt the serp.belt.
any ideas?
any ideas?
ok ill do the plug thing shortly. sucks because i just put all new plugs in it last week. I just went up and down the road a few times, and i got into it - its not missing and all its power is back so im confused.. my steering still is mostly gone, i checked my PS fluid and its full.
I have power steering unless im going slow its all gone - but if i give it gas its good
Its really weird that both started at the same time but my engine is running fine now
If the car is running and driving fine now minus the steering issues then you may be ok and not chipped a piston. Most likely when the multiple misfires started the ECM pulled power to keep it from going boom.
Sounds like you could use a new set of plugs and wires, fuel filter, clean the MAF. Then see how it runs. Although w/o a way to actively scan it for KR you're asking for a new motor if you run it that hard again.
Ok so if that was KR -- what could I do to have the chances of it not to come back?
