Thread: I have KR
Results 1 to 20 of 32
  1. #1 I have KR
    SE Level Member hcokiid18's Avatar
    May 2011
    Dayton, Ohio
    was driving home last night and thought about making a video - instead i ended up hitting about 120mph and my power steering went out and my car began missing if trying to accelerate. Wasnt the serp.belt.
    any ideas?
    04 GTP Comp G. 3.4'' Pulley, Pace setters, 180*STAT, Tuned,Slotted Rotors,Thrasher Intake, 152k
  2. #2 Re: I have KR
    Yes.. I changed your title to a better fit.
    You have KR.
  3. #3 Re: I have KR
    Ohio
    bill your soo nice
  4. #4 Re: I have KR
    Out West
    You probably chunked a piston.
  5. #5 Re: I have KR
    May 2011
    Dayton, Ohio
    your kidding........... what can I do ?
  6. #6 Re: I have KR
    Out West
    Quote Originally Posted by hcokiid18 View Post
    Stop going 120.
    Get a new engine.
  7. #7 Re: I have KR
    On the power steering. check your fluid level.
  8. #8 Re: I have KR
    May 2011
    Dayton, Ohio
    first time I hit 120. I dont drive it like that ever.
  9. #9 Re: I have KR
    Out West
    Just means you weren't meant to go 120.
  10. #10 Re: I have KR
    Kansas
    New engine FTW!
  11. #11 Re: I have KR
    Out West
    Pull your plugs and check for smashed plug.
  12. #12 Re: I have KR
    May 2011
    Dayton, Ohio
    ok ill do the plug thing shortly. sucks because i just put all new plugs in it last week. I just went up and down the road a few times, and i got into it - its not missing and all its power is back so im confused.. my steering still is mostly gone, i checked my PS fluid and its full.
  13. #13 Re: I have KR
    May 2011
    Dayton, Ohio
    I have power steering unless im going slow its all gone - but if i give it gas its good
  14. #14 Re: I have KR
    pumps dead. replace it.
  15. #15 Re: I have KR
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    I have KY, what does it all mean?
  16. #16 Re: I have KR
    Kansas
    I take it you've never drove a vehicle with no power steering ever.
  17. #17 Re: I have KR
    May 2011
    Dayton, Ohio
    Its really weird that both started at the same time but my engine is running fine now
  18. #18 Re: I have KR
    change your pump while its still got life in it, if you drive the car when its dead, you will kill your rack and pinion.
    its only going to get worse from here on out.
  19. #19 Re: I have KR
    St. Louis
    If the car is running and driving fine now minus the steering issues then you may be ok and not chipped a piston. Most likely when the multiple misfires started the ECM pulled power to keep it from going boom.
    Sounds like you could use a new set of plugs and wires, fuel filter, clean the MAF. Then see how it runs. Although w/o a way to actively scan it for KR you're asking for a new motor if you run it that hard again.
  20. #20 Re: I have KR
    May 2011
    Dayton, Ohio
    Ok so if that was KR -- what could I do to have the chances of it not to come back?
