Thread: I have KR
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #1 Re: I have KR
  2. #2 Re: I have KR
    Or a proper pulley size.
  3. #3 Re: I have KR
    SE Level Member hcokiid18's Avatar
    May 2011
    Dayton, Ohio
    I scanned my car and im only getting 3 codes besides my ABS sensor - p0036,p0134,p0141all o2 sensors.
    04 GTP Comp G. 3.4'' Pulley, Pace setters, 180*STAT, Tuned,Slotted Rotors,Thrasher Intake, 152k
  4. #4 Re: I have KR
    Minnesota
    I bet your power steering went or is going out and you have a bad upstream O2.
    I see that the picture you have is not an 04. Is your 04 with mod list what you have now?
  5. #5 Re: I have KR
    May 2011
    Dayton, Ohio
    my power steering went out on me yesterday completely!! my picture is my 99 GTP I sold, my mod list is my 04 I drive daily. How'd you know my steering went out, besides reading my posts?!?
  6. #6 Re: I have KR
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    lol well can u hear any knocking cuz if u have a chipped piston im sure youd hear it also next time u change your oil check for any metal shavings
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  7. #7 Re: I have KR
    May 2011
    Dayton, Ohio
    i dont hear any piston noise, just my coupler.
  8. #8 Re: I have KR
    Jun 2011
    At least you don't have crabs!
  9. #9 Re: I have KR
    Minnesota
    I bet if you replace the upstream O2 you will be good to go. I would also do a once over of everything like the plus and ect.. Then I would still have someone tune/scan your car and not just for codes
    I knew your pump would take a crap on you because of what you described. You probably had a bad pump already but the high RPMs from going 120mph just helped it along faster.
  10. #10 Re: I have KR
    May 2011
    Dayton, Ohio
    Yeah im probably gonna pick up a used one for $30, could you point me in the right direction of where the upstrearm 02 is? Im not the best mechanic especially for having a modded car!
    Also - I do know the o2's (or one) is in the exhaust -- tried looking for it once and couldnt. Im missing my passenger side muffler completely.
    Thanks in advance!
  11. #11 Re: I have KR
    Minnesota
    Upstream O2 sensor is in the rear manifold on the car. I have TOGs so I do mine from under the car but I am not sure about Pace Setters.
    It does make some sense about the O2 but I would also check to make sure you have all the plug wires on tight and in the correct order. I would also make sure you didn't crack any of the porcelain on the plug putting them in.
  12. #12 Re: I have KR
    May 2011
    Dayton, Ohio
    one of the dang plugs in the back keeps breaking porcelain everytime I pull it out, i believe my headers are in the way even when I pull the motor forward so im not putting it in the right way I guess... I would tighten it in just a little and to get it back out was a dam job! It acted like I had it as tight as possible when I really didnt, so when I would finally get it out the top porcelain part would be cracked... ( happened 3 times in the same spot ) getting tired of messin with the damn thing.
