Thread: Heater stopped working
Results 1 to 4 of 4
  1. #1 Re: Heater stopped working
    GT Level Member shart's Avatar
    Oct 2011
    Reading PA
    Quote Originally Posted by bps02gtp View Post
    it could be clogged and you can unclogg it by taking the hoses off the heater core at the fire wall and then taking a hose and blasting water through it in both directions till you get an evenly fast flow coming out both sides.
    To add to this, if water does come flowing out when you spray it with a hose, you may want to take of the actual hose that goes to the heater core and make sure they are not clogged at all also
  2. #2 Re: Heater stopped working
    St. Louis
    Or, your blend door is stuck and not switching over to heat properly. Check the actuators for vacuum and see if they are still working or not.
  1. Tap shift Stopped working
    By dlemmen in forum General Tech Discussion
    Last Post: 06-16-2011, 07:29 PM
  2. Fog lights stopped working
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 04-25-2011, 09:02 PM
  3. speedometer stopped working..
    By JoeC9107 in forum General Tech Discussion
    Last Post: 03-19-2011, 06:00 PM
  4. air con stopped working
    By Tha Ghost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-20-2011, 04:14 PM
  5. Heater stopped blowing
    By monsterjam5000 in forum General Tech Discussion
    Last Post: 07-25-2010, 11:02 AM
