Thread: Why do i keep blowing this fuse?
Results 1 to 4 of 4
  1. #1 Why do i keep blowing this fuse?
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    I've replaced my interior lamp fuse 3 times in the matter of 2 days. ...Why?
  2. #2 Re: Why do i keep blowing this fuse?
    GT Level Member shart's Avatar
    Oct 2011
    Reading PA
    Are you sure your using the right fuse for it? Other then that, its got to be shorting out somewhere causing the fuse to blow...
  3. #3 Re: Why do i keep blowing this fuse?
    Oct 2011
    New Jersey
    Yep i'm positive it's the correct fuse. I have no idea what would be shorting it out either
  4. #4 Re: Why do i keep blowing this fuse?
    Oct 2011
    Reading PA
    Unfortunately I don't know of an easy way to check... the wire could be fine and it could be the actual piece that connects that the bulbs go in... if possible see if you can trace the wire and check for any exposures
  1. keep blowing fuse for fog lights.
    By RyanL in forum Audio, Security & Visual Electronics
    Last Post: 10-30-2011, 01:58 PM
  2. Help with blowing reverse fuse
    By ck115 in forum General Tech Discussion
    Last Post: 08-02-2010, 09:05 PM
  3. Keep blowing Injector fuse
    By ninnyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 07:40 AM
  4. Blowing MAF Fuse, SES Light, P0102
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2010, 08:53 AM
  5. MAF Fuse Blowing
    By shoboy07 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2009, 07:05 PM
