Thread: Traction Control ON/OFF
Results 1 to 17 of 17
  1. #1 Traction Control ON/OFF
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    Is there anyway to turn off the traction control button near my HUD at the center console. I see the TCS and to the left of it theres two sections where i think lights should be on or not. I just dislike it on because I just got my car and whenever i try to do a 0-60 run i think my wheels spin out because i lose all acceleration until i let go of the peddle. It's a 98 GTP if that helps.
  2. #2 Re: Traction Control ON/OFF
    on the DIC there should be a TC button that you can push to turn the tc on or off.
  3. #3 Re: Traction Control ON/OFF
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
  4. #4 Re: Traction Control ON/OFF
    Ummm...lol or pull the fuse out for free?
  5. #5 Re: Traction Control ON/OFF
    GT Level Member shart's Avatar
    Oct 2011
    Reading PA
    Really? 35 dollars when as pointed out you could just pull the fuse? Until i start ****ting out money when i go to the bathroom, ill stick with the fuse.
  6. #6 Re: Traction Control ON/OFF
    even with my traction control off on my 98 gtp it still bogs if you spin over 4K rpms.
  7. #7 Re: Traction Control ON/OFF
    michigan
    Didn't see the big ass button??! Wtf
  8. #8 Re: Traction Control ON/OFF
    Nov 2011
    Indiana
    Yea I've been aware of that TCS button, but the lights for the Low Trac and TCS Off dont light up or do anything when i press the button. Could this be solved if i got better wheels with better grip and traction? Completely flooring it is impossible as of now.
  9. #9 Re: Traction Control ON/OFF
    what happens when you floor it? wheel spin or trac control making your engine studder?
  10. #10 Re: Traction Control ON/OFF
    Motor/Trans Mounts could be shot as well...
  11. #11 Re: Traction Control ON/OFF
    Bunnell, FL
    glad i have a 97
    no tcs
    however i still added the button cause the 97 gtp dic looks dumb as hell
    I'm a Sex Offender
  12. #12 Re: Traction Control ON/OFF
    Nov 2011
    Indiana
    I;m not sure, i would have to try it again. I just know there's usually a loud squeal if im at a stand still and punch it. Then the RPMS Go up but the acceleration doesn't go higher until i let go of the gas pedal and then accelerate.
  13. #13 Re: Traction Control ON/OFF
    so it feels like the trans is slipping?
    maybe go to a trans shop and see if you have any stored trans codes.
    i think there is a fuse you can pull to disable the trac control too, that may rule that out, if the squeal still happens, or pull a hub sensor wire off, that will disable the trac control for sure lol
  14. #14 Re: Traction Control ON/OFF
    Nov 2011
    Indiana
    Could be. I Just know the RPMS stay at the spot before the *power?* cuts out of the acceleration. Its only when i put the pedal to the floor real fast. Gradual acceleration is fine and also flooring it when im at a steady high speed (lets say 35 and up?) its fine. I wanna say its the tc kicking in shutting off the acceleration til i let go of the gas and gain traction again.
  15. #15 Re: Traction Control ON/OFF
    my car feels like its studdering, and just quits having any power till i let off the gas and get into again when the trac control kicks in. when i have the trac off, it feels like a whole different animal when jumping on it.
    i drive a regal, so my dash shows a low trac light when it kicks in.
  16. #16 Re: Traction Control ON/OFF
    Nov 2011
    Indiana
    My car doesn't feel like its studdering i believe, just seems like no power until i re-accelrate. Either get that light and button fixed or manually disable TC under the hood?
  17. #17 Re: Traction Control ON/OFF
    i'd start with disabling the Tc, if your problem goes away, you know why its happening.
  1. traction control
    By rodburner in forum General Tech Discussion
    Last Post: 07-06-2011, 08:38 PM
  2. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  3. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
  4. Traction Control
    By Dewey1964 in forum Brakes/Suspension/Chassis
    Last Post: 05-02-2010, 11:06 PM
  5. ABS/Traction control
    By holsports in forum General Tech Discussion
    Last Post: 03-22-2009, 11:32 AM
