Thread: Official Axby Replacement/Upgrade Thread
Results 1 to 2 of 2
Axby523 Official Axby... 05-31-2012, 02:16 PM
matt5112 If youre modding copper works... 06-02-2012, 05:45 AM
  1. #1 Official Axby Replacement/Upgrade Thread
    Donating Users Axby523's Avatar
    May 2012
    Canada
    I created this thread for two reasons;
    i) I have a place where I can keep a list of all my information on parts and pricing.
    ii) Knowledge center for people to check prices quickly as well comment on.
    In regards to the comments my current knowledge level of brands is at .5 out of 10 when it comes to car parts. The .5 comes from the front sway bar. Any information on brands to go for and shy away from would be great for any of the parts listed bellow.
    Text Color Legend:
    Black - Not Started
    Green - In process
    Red - Complete
    If you have any questions or would like something added to this list PM me.
    NOTE#1: All prices are in Canadian Dollars.
    NOTE#2: Research on these forums suggest shipping with UPSS to conserve money at the boarder.
    Car: 2002 Pontiac Grand Prix GTP 40th Anniversary Edition
    Code Name: Joani
    Front Sway Bar: I have decided to go with Dorman over the Progress Bar from ZZP (Solid) / SLP Front/ Rear Pkg from 3800 Performance (Solid) / GMPP (Hollow)
    Dorman Package includes the bar, bushings and links.
    NAPA: $191
    CarQuest: $150.50
    PartSource: $153.02
    Front Sway Bar Links: Research on this forum leads to conclusion to replace Dorman hardware with Moog and tighten profusely.
    Moog
    NAPA: $18.10/link
    CarQuest: N/A They don't carry Moog
    PartSource: $7.68/link
    ZZP: $13.99/pair + Shipping
    Serpentine Belt: I am not sure of the makes of them except for PartSource. I have not done research on the different types and the advantages of an upgrade.
    Replacement for split stock supercharger belt with 3.8" pulley
    NAPA: $44.40
    CarQuest: $49.20
    PartSource: $51.00 (Goodyear Make)
    ZZP: $30.99 + Shipping
    Fuel Filter: According to ZZP the fuel filter is a minor detail that can hinder your upgrading project. They are cheap and worth replacing especially if it is the stock OEM.
    NAPA: N/A Still need to call
    CarQuest: $10.00
    PartSource: $13.00 - $14.00 (GK Industries) *Upgrade
    ZZP: $14.99 + Shipping *Upgrade 20% increase fuel flow over stock OEM part
    Iridium Spark Plugs: At 160000 km these should be check / replaced. The guy at NAPA said Iridium is the only way to go with the GTP. You can get poor results with anything else.
    NAPA: $16.20/spark
    CarQuest: $18.21/spark
    PartSource: NGK $8.99/spark
    ZZP: $44.99/six pack + Shipping
    Dog Bones: These are the two cool things we can paint that are located on the back of the Radiator and hold the front of the engine. Most come with the bushing pre pressed.
    NAPA: $55.90/bone
    CarQuest: $12.00/bone (seems really cheap to me)
    PartSource: N/A couldn't find the part
    ZZP: Polished Billet Dog Bones $131.99/pair + Shipping (These look really sweet)
    They have 1" shorter dog bones if you need to lift the engine up from the front sway bar however this can have negative side effects based on research found on this forum.
    If youre modding copper works well but needs to be changed often.
    Moog links are probably the best balance between cost/perf. Also if you buy the dorman bar youll want to pick up two sway bar bushings, moog as well. 1.26" bar.
    Partsource/ct can get those dogbones. They can get anything if they feel like it.
    Most will suggest skipping stock replacements and opting for poly mounts for both engine and rad support sides. Can add little vibration but shifts will feel much better. Mostly downshifts.
    They can also get you a rear 7/8" solid addco sway bar for ~$180+ tax. It will come with bushings but still require new links. Again moog recommended. Make sure its not trw if getting from partsource.
    Napa belts are made by gates iirc which are supposed to be better in resisting slip.
    Wouldnt recommend prestone belts from partsource/ct. They seem to be short and crack quickly.
    Youll also want new lca's. Price out dorman and moog. If anyone tries to sell ac delco for cheap ask which line. Advantage line is econony quality. Something to be avoided.
  1. Official - Photoshop Thread
    By rocafella2032 in forum Off Topic Discussion
    Last Post: 01-04-2010, 05:57 PM
  2. Official Wallpaper Thread
    Last Post: 10-30-2009, 01:07 AM
