Thread: Passenger window only goes halfway up
Results 1 to 6 of 6
  1. #1 Passenger window only goes halfway up
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    I have a two door GTP, and the passenger window never fully goes up. I'll sometimes have to keep hitting "up", then "down" until it shimmy's up there. If i just hold the up button, it goes up really fast then slows down till halfway, then completely stops. What's wrong here?
    Regulator, sticky track, or switches need cleaning. I'm leaning towards the first two.
  3. #3 Re: Passenger window only goes halfway up
    Ocala, FL
    ^^ what he said.. Only other thing I've seen is the rubber weather stripping gets messed up. Have someone else roll the window up while and make sure it's not catching anywhere.
  4. #4 Re: Passenger window only goes halfway up
    St. Louis
    Lube up the felt guides in the window track and see what you get before you break the regulator. Sounds like its dry and grabbing the glass. I keep mine slicked up and have yet to loose another regulator.
  5. #5 Re: Passenger window only goes halfway up
    lubing the window track up with wd-40 or slicone spray is a bad idea, as it attracts dust and dirt and clogs up the track.
    my last truck ate 3 pass side regulators the last one lasted forever. i sprayed it with graphite for locks in spray can. worked like butter.
  6. #6 Re: Passenger window only goes halfway up
    St. Louis
    Yep, exactly what I used. Def. don't use WorthlessD-40 on it.
  1. Problem with passenger window
    By Warlord55 in forum General Tech Discussion
    Last Post: 08-31-2010, 05:00 PM
  2. Passenger window will not roll all the way up
    By kevinpope in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2010, 05:39 PM
  3. passenger window problem.. LOOK
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2010, 12:50 AM
  4. Fixing passenger window
    By GEMINIokc in forum General Tech Discussion
    Last Post: 08-23-2009, 09:30 PM
  5. Why is my passenger window p*ss slow?
    By Z28 in forum General Tech Discussion
    Last Post: 03-25-2009, 09:41 PM
