Thread: No heat blowing in the car
Results 1 to 9 of 9
  1. #1 No heat blowing in the car
    Rockwood
    I have a 2005 GP base model with a 3.8 Series III and I have no heat blowing into the car. Blower motor works, fluid level is full, but still no heat. What could be the problem and how do I fix it?
  2. #2 Re: No heat blowing in the car
    http://www.grandprixforums.net/moms-...eat-53666.html this thread has the same problem, you may find a answer in it.
  3. #3 Re: No heat blowing in the car
    GT Level Member GMCustomerService's Avatar
    Michigan
    @jbaker4433, I can understand how frustrating this must be for you. Did you get this taken care of? Did you contact the dealership to see if they could offer any avenues for you to try to follow to get to the root of this?
    Michelle, GM Customer Service
  4. #4 Re: No heat blowing in the car
    Rockwood
    Unfortunately I have not figured it out. Don't have a clue now. I have tried everything.
  5. #5 Re: No heat blowing in the car
    Donating Users falconjohnd's Avatar
    Aug 2011
    new fairfield ct
    Blend door actuator is the usual culprit.
  6. #6 Re: No heat blowing in the car
    Rockwood
    Where would they be at and how do I get them off or check them out?
  7. #7 Re: No heat blowing in the car
  8. #8 Re: No heat blowing in the car
    Aug 2011
    new fairfield ct
    there are two one on each side under the dash near the center concole. If you have digital heat they are about 68 bucks each about half that if you dont have digital. My car is older than yours so it may not exactly be the same. i found an article on here how to replace it.
  9. #9 Re: No heat blowing in the car
    Oct 2011
    Chicago area
    same problem with my 07. Dealer said I had an air lock, bled the system and problem went away. I also had the gurguling sound, 1st time was water in blower area and second thin they did the above.
  1. blowing air,,but not hot
    By mimi in forum General Tech Discussion
    Last Post: 12-14-2010, 02:40 AM
  2. Blowing cold air
    By tracker1925 in forum General Tech Discussion
    Last Post: 12-11-2010, 06:41 AM
  3. heater not blowing hot air
    By mfowler12 in forum General Tech Discussion
    Last Post: 12-09-2010, 11:19 PM
  4. MAF Fuse Blowing
    By shoboy07 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2009, 07:05 PM
  5. A/C stopped Blowing
    By RedGPGT in forum General Tech Discussion
    Last Post: 06-27-2009, 09:15 AM
