Thread: battery light came on and went off! puzzled
Results 1 to 12 of 12
  1. #1 battery light came on and went off! puzzled
    SE Level Member baker01gt's Avatar
    Sep 2011
    houston, TX
    on the way home from work when i started my car i noticed the battery light was on. i turned off the radio and everything to get home and made it without the car dieing. the car was running low rpmsbut still running. about half way home the battery light turned off the the rpms went back too normal, and once this happened i noticed a elictric burning smell, that consisted with the car running. tyhe smell is very faint but when you open the hood you can smell it. to see if it was my alternator i disconnected the battery before i turned the car off and the car died right away. i quickly took it to autozone anfd they said my battery was bad whitch made no sence because the car still startes and drives. its only when i disconnect my battery while the car is running is when it dies. the battery light has not come back on but i can stiull smell the burning smell.. i dont wanna spend money on an alternator if it could be something else. PLEASE any advise will help. (the lady at autozone didnt seem like she really knew what she was talking about)..
    01 grand prix gt 3.8 146K (original alternator)
    sorry for the novel(i only drove the car about 20 since the battery light came on then went off. what to do)??
  2. #2 Re: battery light came on and went off! puzzled
    Houston
    Check your battery cables....I had my battery move once and the cable was rubbing on the s/c idler pulley. I know that yours is GT, but its still worth checking. Also, it may be your alternator on it's way out. Remove it and have AZ test it for free.
  3. #3 Re: battery light came on and went off! puzzled
    Sep 2011
    houston, TX
    update!!
    i took my car to different auto parts store and they told me again that my battery was bad but also that my alternator had a bad electrode(or something like that) and it also needed to be replace. they said that while my alternator was going bad it caused my battery to go bad as well. i went ahead and bought an alternator and will replace tomorrow.. after that i will see if my battery really needs to be replaced or if it will recharge.. i may replace my battery cables while im doing everything else(does anyone know if replacing the battery cables is very hard)??
    THANKS!!
  4. #4 Re: battery light came on and went off! puzzled
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Replacing the cables are probably pointless unless they look screwed up. Ur story has all the symptoms of an alternator going bad. 146k is good life for one. As far as ur battery goes, it can still be bad and keep enough juice to get it started. So u can leave it but eventually it'll be completely dead and will need to jump it to get it started. For batteries idk if u know but in my opinion interstate is the BEST.
  5. #5 Re: battery light came on and went off! puzzled
    Houston
    I agree with bps02 if your cables look good, and your headlights/interior lights are still bright. But it is still good preventative maintenance to replace them. Those cables have been there for 10+ years. Here is a walk thru with some pics that I found. Grand Prixs Of North America • View topic - The Big 3, Everything You Wanted to Know + DIY
  6. #6 Re: battery light came on and went off! puzzled
    Sep 2011
    houston, TX
    ok.. i will double check the cables before i do anything..
    Thanks for the help guys! im about to change the alternator in about an hour or so and if the battery needs replacing too i will look into an interstate! thanks again..
  7. #7 Re: battery light came on and went off! puzzled
    Sep 2011
    houston, TX
    update again!
    i replaced my alternator which only took about 20 min. or so! i checked my battery cables and they still looked fine for now!
    when i took my old alternator back to get my core return, i asked them again to check my battery and stuff. they again said my battery is still bad. the car is still starting and running fine so im not sure what to do.
    do i buy and new battery just because two places told me it was bad or do i stick it out and carry my jumper cables til i end up needing them.
    my car idles juat a little low and has been the last month or so and ive been told that a bad battery can cause low idle and hard start sometime(and my car takes a couple cranks SOMETIMES).
    not sure what to do, what would you do???
  8. #8 Re: battery light came on and went off! puzzled
    Houston
    Replace the battery. Jumper cables are only good if there is another car around. Batteries like to die when nobody is around.
  9. #9 Re: battery light came on and went off! puzzled
    Nov 2010
    Illinois
    Lol that's true ur battery would die at the worst time. Me personally if I was tight on money id squeeze all the life out of it. Its really all up to u. As far as idling and what not goes, are u sure ur car ever got the proper tune up?
  10. #10 Re: battery light came on and went off! puzzled
    junk yards sell battery's, for cheap, if your tight on cash that is.
  11. #11 Re: battery light came on and went off! puzzled
    PA
    Quote Originally Posted by baker01gt View Post
    As mentioned, the symptoms that you posted all sound like a bad alternator. And the alternator can cause the battery to be low and not charge well afterwards. I would keep running it and if it starts showing signs of going bad, replace it.
    But what I quoted above is not a good idea to do. Disconnecting the battery can cause a surge of power from the alternator through your electronics and can cause major issues. While nothing happened this time, you should never disconnect your battery while the car is running.
    2001 GSE
  12. #12 Re: battery light came on and went off! puzzled
    Sep 2011
    houston, TX
    thanks alot guys!! im still deciding whether to buy a new battery or not. not that im tight on funds just that it really hasnt shown any signs of being very bad since ive changed the alternator.. (exept the low idle sometimes).
    ive just recently done a complete tune up, plugs, wires, oil, air filter, fuel filter, ect..(and alot of other misc. parts)
    and yes, i heard about the dangers of disconnecting the battery while the car was running, but after i had already done it.(for sure wont do it again)..
    i talked to a couple of people about it and some say the bad battery could effect my new alternator in the long run so i may just change it pretty soon..
    THANKS for ALL the advise!! much appreciated..!
  1. check gauges and battery light on
    By gtpwilson in forum General Tech Discussion
    Last Post: 10-30-2011, 06:01 PM
  2. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  3. "CHECK GAGES" And Battery Light?
    By K7Gixxer750 in forum General Tech Discussion
    Last Post: 11-22-2009, 04:16 AM
  4. Puzzled and dont know where to start
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2009, 07:55 PM
  5. Battery Light
    By awq134 in forum Introductions/Noob Questions
    Last Post: 04-29-2009, 12:17 PM
