Thread: 2001 GT Sunroof problems
Results 1 to 9 of 9
  1. #1 Re: 2001 GT Sunroof problems
    Grand Rapids, MI
    i just greased the tracks on either side. the seals you can use silicone spray i believe it says in the manual...? might have to double check that but you can renew that seal on the outside if it's looking a little busted.
    either way unless you're leaking you have some sort of motor, sensor, or lack-of-grease problem.
  2. #2 Re: 2001 GT Sunroof problems
    SE Level Member LePrix's Avatar
    May 2011
    Ottawa, ON
    Thanks for the help.
    What did you apply it with?
  1. Sunroof problems
    By Neil98gt in forum General Tech Discussion
    Last Post: 09-24-2011, 03:41 AM
  2. 2001 3800v6 problems
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 09-10-2010, 11:47 PM
  3. 2001 gt traction control problems
    By kirkq20 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-17-2009, 08:24 PM
  4. Sunroof problems
    By FT133 in forum General Tech Discussion
    Last Post: 07-29-2009, 02:28 PM
  5. 2001 GTP problems
    By eli2020 in forum General Tech Discussion
    Last Post: 07-05-2009, 01:02 PM
