Thread: Standard tune up/LIM questions
Results 1 to 20 of 22
  1. #1 Re: Standard tune up/LIM questions
    That little guy will retrieve OBD2 codes and clear them.
    Diagnosing takes learning symptoms and interpreting them along with a good site that has the FSM info for the codes, like GearChatter.com
    Then it's about getting experience and each item you fix/diagnose gives you that experience. Hang out with local car guys and you'll gain even more info quicker.
    That little guy won't give you running info though. Like RPM, TPS position, EGR pintle position etc. That's all good info to have as well. But with each added area you add some cost.
  2. #2 Re: Standard tune up/LIM questions
    Aug 2011
    'Merica
    There are not a lot of car guys around here that are not Rice so I learn as much as I can from here. So far it has been a great expierence.
  3. #3 Re: Standard tune up/LIM questions
    Guy..you are in Ohio.. Intense is based in Ohio..last I knew one of the local GP forums in OH was the largest that I've heard of.
  4. #4 Re: Standard tune up/LIM questions
    Aug 2011
    'Merica
    Where is this located in Ohio? Remember i'm noob and my network doesn't reach too far yet. If you look on the map I am located at the intersection of I-70 & I-77.
  5. #5 Re: Standard tune up/LIM questions
    Do a search on Grand Prix Ohio. I came up with a mid state, and couple others. I want to think it was gogp or something like that. But there's plenty of GP guys in Ohio.
  1. what options came standard on 97 gtp?
    By ndgprix in forum Off Topic Discussion
    Last Post: 03-16-2011, 06:21 PM
  2. What are the standard interior colors for a
    By mcsddd in forum Visual/Body Modifications
    Last Post: 07-03-2010, 11:04 PM
  3. Bose Audio or Standard?
    By FriboRage in forum Audio, Security & Visual Electronics
    Last Post: 06-27-2009, 04:59 PM
  4. 98 standard trans??
    By justwhisen in forum General Tech Discussion
    Last Post: 07-31-2008, 03:28 PM
  5. OnStar standard???
    By Randy_W in forum Off Topic Discussion
    Last Post: 06-26-2008, 11:56 AM
