Thread: 3.6 do I need a new belt?
Results 1 to 4 of 4
  1. #1 3.6 do I need a new belt?
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    The one I got is already new. Do I need to drop a size or should I be good??? Any odd recomendations to help it say tight would work to (wow that sounded sooo bad)
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  2. #2 Re: 3.6 do I need a new belt?
    You should be ok. There are marks on the tensioner to tell you if you are within spec.
    Search for the info on how to tell.
  3. #3 Re: 3.6 do I need a new belt?
    I ran a 3.5" on a stock belt...and some people evenrun a 3.4"...but belt slip is nice.
    3.6" should be fine though man, don't worry.
  4. #4 Re: 3.6 do I need a new belt?
    Oct 2008
    IL
    Thanks fellers. Didnt wanna buy another freeaakin belt.
  1. Size wrench needed to adjust belt tensioner for accessory belt install?
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2011, 09:29 PM
  2. can you run the car without the SC belt?
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2011, 10:09 AM
  3. Belt noise when wet
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2010, 01:10 AM
  4. Driving a GTP without a SC Belt ?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 07-30-2010, 12:18 AM
  5. 3.4 belt
    By xsvtank in forum General Tech Discussion
    Last Post: 05-31-2010, 12:27 PM
