Thread: rubber or hydraulic motor-transmission mount?
Results 1 to 20 of 28
  1. #1 rubber or hydraulic motor-transmission mount?
    GT Level Member shart's Avatar
    Oct 2011
    Reading PA
    So, what do you guys think? Hydraulic or rubber? Both are about the same price... Planning on doing it this weekend (Yes, i still havent done it yet.) and they are around the same price..
  2. #2 Re: rubber or hydraulic motor-transmission mount?
    Grand Rapids, MI
    hydraulic. solid rubber still gave me a slight vibration.
  3. #3 Re: rubber or hydraulic motor-transmission mount?
    solid all the way
  4. #4 Re: rubber or hydraulic motor-transmission mount?
    Oct 2011
    Reading PA
    Im leaning towards hydraulic as it seems to provide the smoothest ride from my research...
  5. #5 Re: rubber or hydraulic motor-transmission mount?
    if all your other suspension and other crap is up to snuff you wont even be able to tell the difference.
    Im running solid mounts on 120k old struts and springs and I cant tell at all. I am also modded a little bit so its a smidge rougher at idle with a few misfires here and there.
  6. #6 Re: rubber or hydraulic motor-transmission mount?
    Grand Rapids, MI
    well i have pretty decent suspension at 106k miles and i had solid motor and tranny mounts at one point and it vibrated at about 60ish mph the worst, i thought it was a tire out of balance for the longest.
    so imo, yes you can tell.
    but on the same token, i had the best feeling shifts with those solid lowers. a WOT second gear shift felt amazing with solids. just sayin.
  7. #7 Re: rubber or hydraulic motor-transmission mount?
    Oct 2011
    Reading PA
    So why do you prefer the solid rubber over the hydraulic? Durability?
  8. #8 Re: rubber or hydraulic motor-transmission mount?
    Oct 2011
    Reading PA
    Yea Brandon, from my previous thread im pretty sure that was you that said you had the same vibration issue that im experiencing around 55 - 65ish at times... Thats why im finally replacing it this weekend...
  9. #9 Re: rubber or hydraulic motor-transmission mount?
    me, yes, that way I wont ever have to deal with them ripping open and slinging fluid everywhere and causing another mess.
  10. #10 Re: rubber or hydraulic motor-transmission mount?
    Grand Rapids, MI
    Right, I mean you can get comfort and what not with the stock mounts.
    Or you can get a solid mount, a few more benefits I guess, and the security of knowing when it breaks you don't have fluid everywhere. But in all honesty, you should replace your mounts before that happens anyway.
    It's all up to you sir. My car is a DD, I like smoothness. If it was just my toy, sure I'd do solid mounts and put up with it.
  11. #11 Re: rubber or hydraulic motor-transmission mount?
    Oct 2011
    Reading PA
    Yea the little vibration at that speed is driving me nuts... i think i am going to go hydraulic just to be safe to hopefully eliminate the little vibration from the old mount.. i just hit the 100k mark a little while ago, and would be willing to bet they are stock mounts yet.... speaking of which... any idea what the stock ones are? Im sure ill see when i pull it out, but just curious. Thanks for the input guys.
  12. #12 Re: rubber or hydraulic motor-transmission mount?
    stocks are fluid filled.
  13. #13 Re: rubber or hydraulic motor-transmission mount?
    Minnesota
    I don't know if this is true for all mounts but:
    Some if not all "Solid" mounts are not actually solid if you cut them open. They basically take the oil out but don't replace it with anything. There is still a cavity in them they will compress over a period of time.
    Good luck actually getting a solid mount. I tried 3 Anchor brand labeled "Solid" mounts and shook them. All of them except the last one made a sound like it was fluid filled. After I drilled into it to make my own solid mount (Because I wanted to check also) I noticed that is was still filled with oil!
    Personally this is what I would do. Here is a link to how to make solid mounts. You can fill them with 3M Window Weld or Black RTV. I choose to go with the Black RTV because I didn't want a supper harsh mount. The only bad thing is it's a mess and it takes almost 3-4 weeks for them to fully cure.
    Here is the link:
    ZZP "solid" motor mount *pics* - The Chicago Garage
    I'm installing mine this week with new CVs and probably going to get poly upper mounts. I will post back how it feels.
  14. #14 Re: rubber or hydraulic motor-transmission mount?
    Oct 2011
    Reading PA
    Hmm... learn something new everyday. Good info. Thanks.
  15. #15 Re: rubber or hydraulic motor-transmission mount?
    Grand Rapids, MI
    Make sure you post back, let us know what you went with and if it helped your vibration.
  16. #16 Re: rubber or hydraulic motor-transmission mount?
    Oct 2011
    Reading PA
    Definitely will buddy, ill do it saturday at the latest... more then likely ill do it one of these nights before then in the dark when i get out of work... i get to impatient.
  17. #17 Re: rubber or hydraulic motor-transmission mount?
    Grand Rapids, MI
    ha, yeah i have the same impatience. got to be done MEOW!
  18. #18 Re: rubber or hydraulic motor-transmission mount?
    Oct 2011
    Reading PA
    Just installed the mount... ran into some frustrating issues getting the motor to line up, but finally got it. I jacked it at a retarded angle or something... anyways.. went with hydraulic. Took it out for test ride and from what I can tell, the vibration is history
  19. #19 Re: rubber or hydraulic motor-transmission mount?
    yeah it helps to have a friend push the engine around a bit to line up the mount for sure, ( you did unhook the dog bones right?) cant wait to do my trans mount, i did the motor mount a week or so ago. i should have done both at the same time, but the motor mount was real bad and i did it in a hurry after work one day.
  20. #20 Re: rubber or hydraulic motor-transmission mount?
    Oct 2011
    Reading PA
    Yes sir. Yea.. that's for sure.. all I had was 120 lb wife... she wasn't much help. Haha. It's interesting though... the one I pulled off looks completely fine. Guess looks don't mean anything.
  1. Solid rubber motor mount
    By jmoore4294 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-21-2011, 04:25 PM
  2. motor mount
    By mosley in forum Introductions/Noob Questions
    Last Post: 03-11-2011, 10:11 AM
  3. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
  4. Motor mount help for 94 GP
    By 954mula in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-07-2008, 12:02 AM
