Thread: headlight
Results 1 to 10 of 10
  1. #1 headlight
    new york
    I posted befor and didnt get a responce i changed my headlights, switched headlights and only the drivers headlight is out high beam only wires are all ok i cant figure out why
  2. #2 Re: headlight
    SE Level Member KirkpatrickJTK's Avatar
    Oct 2011
    Urbandale, Ia
    you may want to check your multi-function switch
  3. #3 Re: headlight
    Becca Boo MizzBecca's Avatar
    Michigan
    you need a new bulb?
    I drive a POS
  4. #4 Re: headlight
    new york
    i changed bulbs and its only one head light
  5. #5 Re: headlight
    Oct 2011
    Urbandale, Ia
    try the multi-function switch
  6. #6 Re: headlight
    new york
    Wouldn't the multi functioon switch make both headlights act up its only the drivers high beam that doesn't work:..
  7. #7 Re: headlight
    GTP Level Member 1ATony's Avatar
    mass
    Possible bad/loose ground on that light?
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  8. #8 Re: headlight
    new york
    checked ground anyone have this problem??
  9. #9 Re: headlight
    new york
  10. #10 Re: headlight
    check for power at the bulb connector on the high beam wire and see what happens
    SMGPFC Member #10
  1. Headlight Help
    By Mrc728 in forum Visual/Body Modifications
    Last Post: 06-24-2011, 11:30 PM
  2. headlight help
    By ZGTP1999 in forum General Tech Discussion
    Last Post: 05-12-2011, 03:28 PM
  3. Two Morimoto projectors one cup...uh...I mean headlight...headlight
    By RedDawnGXP in forum Visual/Body Modifications
    Last Post: 03-23-2011, 05:07 PM
  4. Headlight
    By amwhitey in forum Visual/Body Modifications
    Last Post: 04-28-2010, 10:51 AM
