Thread: throttle body spacer... yes or no?
Results 1 to 15 of 15
  1. #1 throttle body spacer... yes or no?
    GT Level Member shart's Avatar
    Oct 2011
    Reading PA
    I've read good and bad things regarding tb spaces... what is everyone's opinion... yes or no and why.
  2. #2 Re: throttle body spacer... yes or no?
    SWPA
    No, because they don't do anything other than take money out of your pocket.
  3. #3 Re: throttle body spacer... yes or no?
    Topeka, KS
    No not unless your using it to spray something. Like N20 or Meth.
  4. #4 Re: throttle body spacer... yes or no?
    no.
  5. #5 Re: throttle body spacer... yes or no?
    Florida
    Nope, unless you like having a list of stuff in your sig...
    Plus, it's not going to cool, jack ****, especially if you've got a blower.
  6. #6 Re: throttle body spacer... yes or no?
    If you don't have the coolant blocked off at the LIM, it's a coolant leak or hydrolock waiting to happen. There's no positive benefit from it.
    Save yourself some time and effort, dump coolant into your throttle body, swear and scream if your motor survives then trash talk the spacer.
  7. #7 Re: throttle body spacer... yes or no?
    Florida
    when you say block it at the LIM are you saying the port where coolant goes to the blower? where you tap and put screws in.... or are you saying at the head side of the LIM? :-X on a side note... i was reading an engine master magazine... saw something on some V8's called an exhaust cross over... do we have those? please say no
  8. #8 Re: throttle body spacer... yes or no?
    I could say no...and I'd be lying. The cross over is right under the TB.
    As for blocking. Yes at the ports with headless screws. Like in the "how to mod a lim" thread.
  9. #9 Re: throttle body spacer... yes or no?
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Why would the tb spacer cause a coolant leak?
  10. #10 Re: throttle body spacer... yes or no?
    Quote Originally Posted by bps02gtp View Post
    It doesn't cause a "leak" per-say unless you can't install it correctly.
    The coolant ISSUE is there are passages in the throttle body that help cool the rear cylinder head...and the TB spacer blocks off those ports...so your rear bank runs hotter.
  11. #11 Re: throttle body spacer... yes or no?
    Due to the difference in the materials, it's very common for a TB spacer over time to leak. Hopefully it's external and not internal. But both happen commonly.
  12. #12 Re: throttle body spacer... yes or no?
    Oct 2011
    Reading PA
    Thanks for the input everyone... looks like ill find something else to invest my money in...
  13. #13 Re: throttle body spacer... yes or no?
    Florida
    Transmission is always a good bet!
    Little more pricy than a TB spacer, but 12-39283723017231232170321 times more better!
  14. #14 Re: throttle body spacer... yes or no?
    Oct 2011
    Reading PA
    lol yea.... just a tad more expensive.
  15. #15 Re: throttle body spacer... yes or no?
    Nov 2010
    Illinois
    Oh ok. That makes sense y u would have to mod the LIM.
  1. Throttle body spacer?
    By 05PontiacGP in forum General Tech Discussion
    Last Post: 03-04-2010, 09:09 PM
  2. throttle body spacer
    By danross in forum General Tech Discussion
    Last Post: 02-19-2009, 06:40 PM
  3. throttle body spacer
    By NKYspdemon in forum Off Topic Discussion
    Last Post: 06-30-2008, 08:45 PM
  4. Throttle Body Spacer
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2008, 06:21 PM
