Thread: Please help with overcooling issue
Results 1 to 20 of 26
  1. #1 Re: Please help with overcooling issue
    Willoughby, Ohio
    when my LIM gaskets went bad my coolant temp never read up to the quarter mark either, replace the gaskets and the PCV valve and the fixed the issue
  2. #2 Re: Please help with overcooling issue
    Oct 2011
    michigan
    Just replaced the gaskets, no change. I appreciate all the help guys, thanks
  3. #3 Re: Please help with overcooling issue
    Oct 2011
    michigan
    Badass, that's odd. I have never heard of these issues before, and the fact I can't figure it out is killing me. Especially since it should be so simple. At least I'm not alone here.
  4. #4 Re: Please help with overcooling issue
    Oct 2011
    michigan
    Well I ended up replacing the coolant temp sensor with a Delco unit, fixed the issue. I find it odd that 3 different shops swore the sensor was reading correctly, but at any rate that was the problem. Thanks for all the help everyone.
  5. #5 Re: Please help with overcooling issue
    GT Level Member Panzer4's Avatar
    Dec 2008
    Dubai, UAE/Camarillo, CA/New Delhi, India
    Glad you got it fixed (lets hope its permanent this time!) but, if you don't mind me asking, since you were swapping parts, wouldn't it have been cheaper and easier to replace the sensor first, and then all the other gaskets?
    Just wondering - no hate. I guess the lesson to learn is to not trust most shops!
    EDIT: Did you notice any difference in performance due to the low coolant temperature? Or was the temperature reaching normal and the sensor just not reading it correctly?
    Thanks.
    "Cry Havoc! And Let Slip the Dogs of War!"
    Black 2000 GTP: 3.4" Pulley, Resonator/U-bend delete, 180 T-stat, Tuned PCM, Thrasher Intake, Larger Radiator, 17" Konig Tantrum Wheels, Red Air Dams. Coming Soon...Projectors, Lighting Mods, Transmission Cooler, Black Rims, Tinted Tails and hopefully Headers
  6. #6 Re: Please help with overcooling issue
    Oct 2011
    michigan
    The sensor was actually the first thing I replaced. It seems I got a bad one right off the shelf. Kinda ticks me off, that damn thing caused me much aggravation. And about $50 in thermostats. lol The intake gaskets needed to be done anyway, I was just hoping they'd find something while they were in there.
    Well, the car was actually reaching normal temp, the sensor was just inaccurate. That said, I do notice a little more power now that the sensor is reading correctly, and my mileage has gone up almost 2 mpg.
  1. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  2. ABS Issue, Please Help.
    By drewprix86 in forum Brakes/Suspension/Chassis
    Last Post: 12-29-2010, 10:14 AM
  3. A/C issue
    By Silver GTP in forum General Tech Discussion
    Last Post: 09-02-2010, 05:28 AM
  4. A car issue
    By NashGT02 in forum General Tech Discussion
    Last Post: 08-10-2010, 02:05 PM
  5. GTP pcm issue with ZZP
    By Regalgs98 in forum PCM Tuning
    Last Post: 02-18-2009, 02:16 AM
