Thread: Please help with overcooling issue
Results 1 to 20 of 26
  1. #1 Please help with overcooling issue
    Oct 2011
    michigan
    Hey guys, I've got a strange problem. My 04 GTP started throwing a P0128 code which is low coolant temp. So I replaced the temp sensor, which didn't fix the problem so I replaced the thermostat. That worked for about a week. Then I get the same code again. Figured I got a bad thermostat so I replaced it again. Same problem. If I let the car sit and idle, it comes up to temp just fine and the fans cycle on and off as they should. But when I drive it, it never gets even to the quarter mark on the guage. I had it scanned and the coolant temp doesn't get higher than about 174 degrees. I've had it to 2 shops and talked to about 5 more and no one has any idea what's going on. I have great heat in the car, it's just not getting up to normal temp when I'm driving it. Anyone have any suggestions? Thanks
  2. #2 Re: Please help with overcooling issue
    Jan 1970
    Maquoketa, Iowa
    What are the exact thermostats you're replacing it with and do you do any modifications to the t-stat?
  3. #3 Re: Please help with overcooling issue
    Oct 2011
    michigan
    I got one from a Napa store and one from an Autozone, both were 195 degree stats. No mods, just swapped em out.
  4. #4 Re: Please help with overcooling issue
    check the wires on the plug for the temp sensor, they could be all cracked or missing insulation.
  5. #5 Re: Please help with overcooling issue
    CT
    Hmmm how does your coolant look? Also pull your main accessories belt and just grab and wiggle the water pump pulley and check for any play.
    2001 GTP - 3.4" pulley, Headers, welded in flowmaster mufflers, Tune, Intake, SSC/AGX, Engine/Trans mount spacers, GMPP F/R Swaybar, 17" Rims, Built trans: 3.29 gears, 2500 stall, ect ect (built by Billboost)
  6. #6 Re: Please help with overcooling issue
    Oct 2011
    michigan
    Just checked the wires, coolant and water pump, all look good.
  7. #7 Re: Please help with overcooling issue
    What you want to do is confirm the pcm temp is what you see on dash.
    This is an odd problem. Because your tstat keeps the motor temp at 195F when it passes the t stat. If it opens too much, you can overcool. But..the regulating item is the T stat
  8. #8 Re: Please help with overcooling issue
    Oct 2011
    michigan
    How do I confirm the temp is the same? I've hooked it up to a live stream scanner and it looked to correspond pretty well.
    It's very odd and it's driving me crazy. There's not much it could be, or so I thought. I suppose it's possible I got two bad thermostats, but it's pretty unlikely
  9. #9 Re: Please help with overcooling issue
    Charles City, IA
    Point a lazer thermo at the upper rad hose and see what that temp is.
    SMGPFC Two Nipple General
  10. #10 Re: Please help with overcooling issue
    Oct 2011
    michigan
    Well that just sounds too easy. I'll do it tomorrow and post my results. Thanks everyone
  11. #11 Re: Please help with overcooling issue
    Oct 2011
    michigan
    Stopped at the parts store that I got the first stat from to get another one. I figured what the heck, third time's the charm right? I inspected it before I bought it, and it had a nick out of it and didn't seal at all around the whole ring. The other 5 (All Stant) they had in stock were all the same. I passed and went to a Parts Master store and looked at theirs which is a MotoRad, and it sealed perfectly around the whole ring. I'll install it in the morning and see what happens.
  12. #12 Re: Please help with overcooling issue
    Oct 2011
    michigan
    Well I checked the new one on the stove before I installed it and it opened at about 200. Put it in the car and it's still doing the same damn thing. Anyone got any other ideas?
  13. #13 Re: Please help with overcooling issue
    Is the coolant level in the LIM up to snuff or is it low. Might be not taking coolant, which won't give you a good temp reading/fluctuating
  14. #14 Re: Please help with overcooling issue
    Oct 2011
    michigan
    Coolant level is good. Had the intake gaskets replaced today and radiator and heater core flushed. Still having the same issue. Checked the temps with a lazer thermometer today as well, the guage and scanner temp are within a couple degrees, so I know that's accurate. Gonna try a new radiator cap tomorrow.
  15. #15 Re: Please help with overcooling issue
    Oct 2011
    michigan
    Well the new cap did nothing. I thought maybe the fans were coming on somehow while I was driving when they shouldn't so I unplugged the fan relay and that made no difference either. Help!!! This is driving me crazy
  16. #16 Re: Please help with overcooling issue
    Jan 1970
    Maquoketa, Iowa
    Reflash the PCM...?
    Most of us don't know how to fix something that is running better than normal. lol
  17. #17 Re: Please help with overcooling issue
    Ok.. so the pcm and gauge both say it's running cool?
    You did put the rubber gasket on the new t stat right?
  18. #18 Re: Please help with overcooling issue
    Oct 2011
    michigan
    I know it seems strange to be so concerned about it not getting too hot, but that means something somewhere isn't right. I don't like my vehicles to not be right. I don't want it to turn in to a major issue down the road.
  19. #19 Re: Please help with overcooling issue
    Oct 2011
    michigan
    Bill, yes they both show it running cool. there are the 5 "big" marks on the guage..low end, quarter, half, there quarter and high end. There are 3 (I think) smaller lines in between the large ones. It's not getting above the second small line from the large low end mark. Seems to run cooler with the cool weather. I put a Delco stat in it yesterday and it had the gasket already on it so I just popped it in and am still having the same issue. It's turning on my light within minutes of clearing it out.
  20. #20 Re: Please help with overcooling issue
    Willoughby, Ohio
    when my LIM gaskets went bad my coolant temp never read up to the quarter mark either, replace the gaskets and the PCV valve and the fixed the issue
  1. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  2. ABS Issue, Please Help.
    By drewprix86 in forum Brakes/Suspension/Chassis
    Last Post: 12-29-2010, 10:14 AM
  3. A/C issue
    By Silver GTP in forum General Tech Discussion
    Last Post: 09-02-2010, 05:28 AM
  4. A car issue
    By NashGT02 in forum General Tech Discussion
    Last Post: 08-10-2010, 02:05 PM
  5. GTP pcm issue with ZZP
    By Regalgs98 in forum PCM Tuning
    Last Post: 02-18-2009, 02:16 AM
