Thread: cannot redline car
Results 21 to 40 of 41
  1. #1 Re: cannot redline car
    West Side Michigan
    That's not his video...
    you guys fail in the reading department this morning huh?
  2. #2 Re: cannot redline car
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    Nawarkk beat me to it lol.
  3. #3 Re: cannot redline car
    I don't care.
    How many times do I have to post that I don't read things.
  4. #4 Re: cannot redline car
    Jan 1970
    Maquoketa, Iowa
    I don't care.
    Don't worry, we know where you're from haha
  5. #5 Re: cannot redline car
    We have education, just no indoor plumbing or internet.
  6. #6 Re: cannot redline car
    What about me.. you guys know I'm supercharged and answer nearly every post correctly. Once in a while though...I totally miss.
    This is that post. Book mark it so that when I fix a huge issue for cheap...you can say.. "Bill is only human".
    Which...I really am.
  7. #7 Re: cannot redline car
    Jan 1970
    Maquoketa, Iowa
    First gear is usually shifting at a lower RPM than redline anyway. I'm not by my tuner to see what WOT shift point is set at in 1st, but I know it's not near redline.
    Another point is your computer can be set to shift at 5700rpms, but not actually shift until 6000rpms depending on the tranny.
    Another point is if you actually look at the gauge in your car and then at the scanner to see what the pcm is seeing for rpms the dash guage is off.
  8. #8 Re: cannot redline car
    I live here. TLSheff's Avatar
    Is VTEK kicking in yo???
  9. #9 Re: cannot redline car
    Bill isn't human he's sent from the planet L67 in the gm galaxy. Your secret is out bill.
  10. #10 Re: cannot redline car
    That's over in the Regal Quadrant if I'm not mistaken
  11. #11 Re: cannot redline car
    new britain, ct
    he has a 4t60 right because hes a 97 gt? isn't that vacuum powered and not electronically controlled like the 4t65? i dont know much about trannys so...
    07 Black GXP.
  12. #12 Re: cannot redline car
    Pennsylvania
    Probably would be handy to hook up a scanner. Clogged cat, clogged fuel filter, clogged air intake filter, mucky plugs, dying wires, enormous vacuum leak, throttle issue...
  13. #13 Re: cannot redline car
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    Quote Originally Posted by SlowNA06 View Post
    i can eliminate the fuel and air filter, and the plugs and wires. no vacuum codes. so, now where are we?
  14. #14 Re: cannot redline car
    Sep 2011
    MI
    Quote Originally Posted by ctracer View Post
    Arn't trannys them fellas that dress like chicks?
  15. #15 Re: cannot redline car
    SE Level Member 94grandprixNOwhipple's Avatar
    Oct 2011
    Indiana
    My father had the same sort of problem in his GT, turned out fuel injectors were clogged to hell.
  16. #16 Re: cannot redline car
    It's funny...for all the times I hear and read people saying injectors..it's typically something else. Injectors maybe 1% of the time.
    Let's see.. maf and tps have a lot to do with trans shifting. Only real difference between 4T60 and 4T65 shifting is the pcs vs vacuum controlled. This effects the shift pressure, not timing or gear. So we can rule that out.
    Say his tps or maf are off or screwin up. That could do it.
  17. #17 Re: cannot redline car
    Jul 2011
    Michigan
    bad gas milage also. related to tps of maf?
  18. #18 Re: cannot redline car
    Ohio
    yeah that would be related. is it "jerky" at all when driving? act like it almost wants to stall idling? im with nick saying it might be a clogged cat.
  19. #19 Re: cannot redline car
    Jul 2011
    Michigan
    Quote Originally Posted by 99PGPGT View Post
    when it shifts it definetly feels like it boggs down, sluggs alittle. should i do the old 02 sensor trick to check the cat?
  20. #20 Re: cannot redline car
    Fuel mileage and bad shifting, wrong shift points etc can be related to needing a tune up.
    When was the last plug and wire change?
    Last time you cleaned the TB/MAF?
  1. Fail AD for a Sky Redline
    By starscream5000 in forum Off Topic Discussion
    Last Post: 02-09-2011, 01:08 PM
