Thread: premium gas
Results 1 to 20 of 22
  1. #1 premium gas
    SE Level Member 03limitedgtp's Avatar
    Sep 2011
    ohio!
    Who uses premium gas in there gtp and can you notice a difference?
  2. #2 Re: premium gas
    If your not using premium in your BOOSTED car...your asking for trouble.
    Boost + U-Bend + Lots of heat + low octane gas = knock knock fun time?
    Yes.
    91+ or higher, it's just what...2 or 3 more bucks per fill up?
  3. #3 Re: premium gas
    I live here. TLSheff's Avatar
    I was on empty once, broke, only had like 10 bux til payday... had to make the call... went with 87 cuz it was cheaper.... GTP ran like dog sheet! boggy, missed at idle, never again... NEVA!!!!
    just pay the extra amount and skip out on the Vente Iced Mocha @ Starbucks
    Besides... read the owners manual... it states on supercharged option 91 minimum octane required
  4. #4 Re: premium gas
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    My 2001 GTP manual says to run only 93 octane gas, I have never put anything else but that in my car for its full 85,000 miles, runs great.
  5. #5 Re: premium gas
    ^^Most of them say it even in the gas door too...hell I ran 91 in the Cobalt and I run 92+ in the GT because of the aggressive timing tables.
  6. #6 Re: premium gas
    "If your vehicle has the 3800 Supercharged V6 engine (VIN Code I ), use only premium unleaded gasoline with a posted octane of 91 or higher. In an emergency, you may be able to use a lower octane - as low a 87- if heavy knocking does not occur. Refill your tank with premium fuel as soon as possible. If you are using 91 octane or higher-octane fuel and you hear knocking, your engine needs service."
    Section 5-5 of your manual... if you don't have one
    http://www.extendedgmwarranty.com/ow...-GrandPrix.pdf
  7. #7 Re: premium gas
    Quote Originally Posted by 03limitedgtp View Post
    yes, the difference I've seen with folks that use 87 vs 91+ is less motor swaps from predetonation destroying pistons.
  8. #8 Re: premium gas
    Bunnell, FL
    gm lies
    use 62 w/ the lead
    I'm a Sex Offender
  9. #9 Re: premium gas
    West Side Michigan
    Lets say you fill up once a week.
    17 (gallons) x .20 (cents) = $3.40
    $3.40 (weekly) x 4 (weeks in a month) = $13.60
    $13.60 (monthly) x 12 (months in a year) = $163.20
    Don't cheap out and do pay the $163.20 extra. You decided to get a Supercharged vehicle, keep up with what is required. $163.20 a year is not that much to save up.. and that's IF you go through a full tank in 7 days.
  10. #10 Re: premium gas
    Nov 2008
    Waterloo, Iowa
    With that said. 163 a year is better than $400-800+ depending to get a new motor...
  11. #11 Re: premium gas
    SWPA
    Quote Originally Posted by nawarkk View Post
    And that $163 extra, really isn't more money spent when you figure out MPG's. You will get more MPG on 91/93 because the ECU isn't pulling timing and making you run like crap. More MPG = less fuel having to be put into tank.
  12. #12 Re: premium gas
    3.40 times 52 is 176.8
    You forgot a few weeks...
  13. #13 Re: premium gas
    SWPA
    He did salesman math. LOL I always laugh when the owner of the company tries to figure out possible production by figuring possible per day times 5 times 4 for montly possibles.
  14. #14 Re: premium gas
    Apr 2011
    Palm Coast, Florida
    nah, it's that new math that everyone talks about
  15. #15 Re: premium gas
    West Side Michigan
    LOL damn it ya got me haha
  16. #16 Re: premium gas
    GT Level Member dengnath's Avatar
    plus you will burn out O2 sensors if you don't!
  17. #17 Re: premium gas
    what?
  18. #18 Re: premium gas
    SWPA
    Quote Originally Posted by dengnath View Post
    O2 Sensors don't know what octane you are running. They only know A/F.
  19. #19 Re: premium gas
    Just run half a tank of 91 and half a tank of diesel and be done with it,, by by knock
    SMGPFC Member #10
  20. #20 Re: premium gas
    wtf dank I would never do that, maybe like $1 worth of diesel as I hear it makes for a good fuel system cleaner.
  1. Premium fuel required!?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2012, 10:20 AM
  2. 1995 GTP premium sound question
    By Adabow in forum Audio, Security & Visual Electronics
    Last Post: 08-31-2009, 11:34 PM
  3. At what point do I need to switch to premium
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-06-2008, 11:26 AM
  4. Fel-Pro Premium Valve Stem Seals-Anyone use them?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2008, 07:50 PM
