Thread: help need answer to my question
Results 1 to 11 of 11
  1. #1 help need answer to my question
    Sep 2011
    saginaw mi
    i had a 97 gt and i put that motor in a 01 body and i have a 01 wireharness and the plug on the tranny by the vacume and what dose the plug do or what can i do to make it work
  2. #2 Re: help need answer to my question
    utah
    The 97 had a different trans then the 01
  3. #3 Re: help need answer to my question
    you need a 98+ trans to make it work.
  4. #4 Re: help need answer to my question
    Sep 2011
    saginaw mi
    Is their anyway around it like to rewire the plug or what dose the plug do is it the electrionc shift?
  5. #5 Re: help need answer to my question
    utah
    Its wired for a different trans, so there's no real way around it
  6. #6 Re: help need answer to my question
    Houston
    The 97's transmissions rely on vacuum, where the latter years are electronic. Find a 98 trans at a junkyard or install the 97 harness.
  7. #7 Re: help need answer to my question
    Sep 2011
    saginaw mi
    Do u know what the plug dose? And could I cut that plug off and hard wire the 97 plug on for it to work?
  8. #8 Re: help need answer to my question
    Houston
    Not sure, you'd need the pin-outs and you'd prolly still have to use the 97 pcm.
  9. #9 Re: help need answer to my question
    utah
    That wouldn't work. You'd be missing some lines and have too many of others.
  10. #10 Re: help need answer to my question
    Sep 2011
    saginaw mi
    Ok well could anyone tell me what it dose and I have all the vacuum line on just stuck on the plug. The 97 plug has like 7 wires and the 01 plug has like 12 or something like that orcan anybodytell me where I can find a wire digram for both years?
  11. #11 Re: help need answer to my question
    utah
    Im sure u could google them both
  1. Someone please have an answer!!
    By AdamBomb in forum General Tech Discussion
    Last Post: 03-30-2011, 09:07 PM
  2. Replies: 39
    Last Post: 09-14-2010, 03:25 PM
  3. Offset question please answer asap
    By zerolimitsgt in forum Tires & Wheels
    Last Post: 04-03-2010, 06:35 PM
  4. Quick Question, Easy Answer (bolt size)
    By alexsmith0913 in forum General Tech Discussion
    Last Post: 08-22-2009, 05:25 PM
  5. Question needs an answer!
    By Nickell in forum General Tech Discussion
    Last Post: 12-28-2008, 04:46 AM
