P0171 keeps popping up, done so far : changed air filter,gas filter.
cleaned IAC and TB , checked for vacuum leaks nothing found.
Just bought car a month ago, previous owner just did plugs, wires look new.
Sometimes a P0441 - Purge flow code will also show . What should I do next :
smoke test( Cost ? ),O2 sensor replacement,fuel pressure test. Car sumbles a slight bit at idle, but runs great any other time. Mileage seems good at 24 mpg mostly highway. Cold starts good, code usually occurs after 1-2 minutes upon cold start. Help
