Thread: Aftermarket Heated Seat kit
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
  1. #1 Aftermarket Heated Seat kit
    Indiana
    I'm tossing around the idea of maybe getting one of the heated seat kits for the passanger side seat of my 99. Its got leather seats if that is an important piece of information.
    A.) has anyone done of these or heard anything about them?
    B.) are they somewhat easy to install?
    C.) are they safe?
    Here is the link to the one I originally looked at. I haven't looked into a whole lot, probably won't happen until closer to next winter now, but its an idea.
    Custom Heated Seat Kit - GPINT - PFYC.com
  2. #2 Re: Aftermarket Heated Seat kit
    Aug 2008
    KCMO
    havent heard or seen any one use them but it cant be that hard to install
  3. #3 Re: Aftermarket Heated Seat kit
    SE Level Member 02 35thLE's Avatar
    ankeny ia
    My 05 Impala had them when I bought it. Driver side works great but passenger side doesn't. I bought a kit for that side and plan on putting it in this week. I also thought about putting one in my 02 GP passenger seat.
  4. #4 Re: Aftermarket Heated Seat kit
    It's typically cheaper and easier to go pick up the parts from a GP at the junkyard. You need the leather to pull the heater off, the swithc and the module it all connects to under the seat. From there it's easy to do.
  5. #5 Re: Aftermarket Heated Seat kit
    Indiana
    So, If I got lucky and found a leather heated driver seat on a gp at the junk yard, would that work for the passanger side?
    I realize the power seat functions wouldnt work, but could it be rigged up to sit on the non-power rails and wired to work?
    Or did any 97-03 gp's have dual heated front seats?
    Like I said, I havent really researched them so I could probably learn more when I do that, but I figured I'd see if anyone had any personal experience with them on here.
  6. #6 Re: Aftermarket Heated Seat kit
    Banned
    Sioux Falls, SD
    There are tons one 97-03 heated seats, well around here there are. you might be able to pick up a complete seat for $50
  7. #7 Re: Aftermarket Heated Seat kit
    Whatya do is bring a razor knife and cut the leather off the seat. Then grab the wiring/module/switch.
    Use the razor knife or seam ripper to get the heaters off the leather and then pull your passenger seat out and lift the leather. Slide the elements under and rehook the leather. Mount the module to the bottom of the seat and snake the wiring (two wires) from the switch to the seat. Hook the power to the power seat connector under the seat. Install the switch/wiring and you are done.
  8. #8 Re: Aftermarket Heated Seat kit
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    I just checked car-part.com and it looks like the seats are $150-200. I'm thinking of doing what BillBoost mentioned. I'll check some local yards. I think my wife would like a heated seat in the winter time.
    Danielle, what part of Indina are you in. We live 2 hours straight east of Monroeville, IN. If I find a couple local, and can get a deal, it may be worth the drive for you. Let me know if that interests you.
  9. #9 Re: Aftermarket Heated Seat kit
    Indiana
    I'm just south of Fort Wayne.
    I haven't checked into it much more, it kinda died in the next to do list as money is rather tight right now. We have a take a part junk yard here with a lot of gp's so i've heard, maybe i'll get lucky if i ever get there to check them out
  10. #10 Re: Aftermarket Heated Seat kit
    London Ont, Canada
    side note.. did the 04+'s comes with heat at all? my wife is cold all day everyday and i know she would enjoy heat
  11. #11 Re: Aftermarket Heated Seat kit
    Indiana
    Mad Monkey: My friend has a 04 gp gt and it has dual heated leather. im pretty sure they all came with duals.
    Id LOVE to do an interior seat swap to the 04+ (if the $ deal is right)
    When i was looking for my old G6, they even had heated cloth in some of them...i thought that was pretty nice
  12. #12 Re: Aftermarket Heated Seat kit
    Bunnell, FL
    palsut has 04+ heated leather seats in his cars
    I'm a Sex Offender
  13. #13 Re: Aftermarket Heated Seat kit
    London Ont, Canada
    \nice, ive got cloth, however i was driving around in a 2012 sentra a while back that had dual heated cloth.. im sure it can be done with the 04+'s
    danielle - the 04+ seats are amazing, im glad i now have an 05 instead of the 99 lol
  14. #14 Re: Aftermarket Heated Seat kit
    Indiana
    I had a 05 G6GT and had to part with it due to $$ issues. So I decided on the 99.
    Its cheaper payments and has been a good car, hoping it'll get me 5 years or so.
    I'm really considering doing the seat swap instead of messing with the passanger deal. There was a beautiful set of 04+ leather on craigslist about 20 miles from me right after I got the 99...boyfriend kept showing me the link and i was like no, what do i need those for..then i found this site and how easy the swap was...and then they were gone
    ...i need a money tree
  15. #15 Re: Aftermarket Heated Seat kit
    London Ont, Canada
    i heard that!
  16. #16 Re: Aftermarket Heated Seat kit
    Apr 2009
    So if I get the seat and the switch, I'll have all I need to make this happen for my passenger side? Nothing buried under the dash or any relay I will need or anything like that? Planning to head to the salvage yard today before the rain hits us.
  17. #17 Re: Aftermarket Heated Seat kit
    Cut the leather on the outter edge of the seat stitching. The heated seat elements are more toward the interior and you won't get them. Then when you go to pull the leather off, lift the seat bottom piece from the front and seperate it from teh cushion. Careful not to hurt the wire from the heater (back right of the seat cushion area) and pull the cushion off the frame. Then you can see under the seat and disconnect the green and black connectors for the seat covers. Follow that back to the module that's clipped to the seat frame and take the module and the wiring back to the main seat connector. This will give you pins to add into your passenger side connector to make it look factory. Now pull the seat back cover, and the heated switch with about 5 inches of wiring and off you go.
    Says Regal, but all the colors are the same with GM. Follow it and you'll have a passenger seat in no time.
    Now..if you wanna mod your switch panel, that'll take a little more work. It's very possible though.
  18. #18 Re: Aftermarket Heated Seat kit
    Apr 2009
    I bought the entire seat assembly and switch from the console. ($50) I also got the "pigtail" for the harness that plugs into the heat switch (about 6" of wires. I'll look at your schematic over the weekend and see if I can follow it.
    I'm planning to fab up the switch cover to appear as an OEM part - no worries on that. The wiring is what I'm most concerned about at this point.
    Thanks again for the post!
  19. #19 Re: Aftermarket Heated Seat kit
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    i might do this once i have my leather seats
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  20. #20 Re: Aftermarket Heated Seat kit
    The wiring is about 5 wires.
    ignition to the switch
    ground to the switch
    illumination to the switch
    power to the module (already under seat)
    Ground to the module (already under seat)
    Then you have the turn on wire from switch to module and the hi/lo wire to the module from switch.
  1. how to fix a heated seat.
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 11-17-2019, 06:18 PM
  2. heated seat
    By ranchero in forum Introductions/Noob Questions
    Last Post: 01-03-2017, 07:35 PM
  3. heated seat
    By Ricky21 in forum General Tech Discussion
    Last Post: 04-23-2010, 10:43 PM
  4. 2000 GTP heated seat
    By vailskier3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2009, 12:01 AM
  5. Heated Seat
    By Rather B Blown in forum General Tech Discussion
    Last Post: 12-29-2008, 01:46 AM
