Thread: She died on me tonight :(
Results 1 to 3 of 3
  1. #1 She died on me tonight :(
    SE Level Member Gravekeeper's Avatar
    Oct 2011
    Southern Indiana
    So the '94 SE decided to die on me earlier. She's been running perfect recently and I just got back from work. Decided to run to the store and it started up and ran just fine again. Well, went into the store and came back out. Maybe 20 mins. When I tried starting the engine she lost all power. Nothing at all on the inside. Was able to check the battery and it's still more than good. Over the next hour and a half me and a couple buddies were checking it out I got power back again until the key was turned to start the engine. Everything died again just as the key was turned. This is so not cool lol.
  2. #2 Re: She died on me tonight :(
    St. Louis
    Remove both battery cables and clean the battery terminals and the cable ends. Then retighten and see what you get. Often this is a sign that one (or both) of the cables is corroded or loose. My 00GT did this to me once and it was a loose cable.
  3. #3 Re: She died on me tonight :(
    Oct 2011
    Southern Indiana
    That was the first thing I checked. They were fine. Looking like the ignition switch. Should be able to change it out this weekend. Wish I could during the weekend, but working second shift kind of gets in the way of that.
  1. My car died
    By GPGTkid01 in forum General Tech Discussion
    Last Post: 10-20-2009, 08:25 PM
  2. died
    By Cjs02GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-08-2009, 08:46 PM
  3. So..... The gtp has died... =[
    Last Post: 08-08-2009, 02:55 PM
  4. died
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2009, 06:21 AM
  5. Where I'll be tonight...
    By Reflective Concepts in forum Off Topic Discussion
    Last Post: 05-02-2009, 11:00 AM
