Thread: 2002 HVAC/Ignition/DRL problem
Results 1 to 5 of 5
  1. #1 2002 HVAC/Ignition/DRL problem
    Oct 2011
    New Jersey
    I have a 2002 Grand Prix GT. I just replaced my climate control, blower, and blower resistor because water got into the components through where the cabin air filter should have been. All worked fine for tow to three days, then intermittent failure, then it all went out all together including the rear defroster. Each time I attempt to turn the fan on again the DRL goes out until I shut it off and restart the car. Then DRL works again. I was advised that the wiring at the climate control and resistor connectors were notorious for burning out.
    This all started after the ignition stopped going into the OFF position. I’m using the manual workaround under the steering column for that for now when I park the car.
    Any ideas?
  2. #2 Re: 2002 HVAC/Ignition/DRL problem
    It does sound like a bad ignition switch.
  3. #3 Re: 2002 HVAC/Ignition/DRL problem
    Oct 2011
    New Jersey
    Will replacing the ignition switch cause me to have to reprogram the keys and remotes?
  4. #4 Re: 2002 HVAC/Ignition/DRL problem
    Sep 2011
    pa
    I just replaced the ignition switch on my sons 2002 GTP, on 10/13/11, no reprograming was needed. if you have any other questions feel free to email me at emackey1@verizon.net
  5. #5 Re: 2002 HVAC/Ignition/DRL problem
    Oct 2011
    New Jersey
    Thanks! Will do.
  1. key stuck in ignition 2002 grand prix
    By bidiheston in forum General Tech Discussion
    Last Post: 01-24-2010, 05:39 PM
  2. Ignition problem
    By kamamm in forum General Tech Discussion
    Last Post: 01-16-2010, 10:38 AM
  3. 94 3.1 has ignition problem
    By 94prixer in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-13-2009, 01:53 PM
  4. 2002 won't release key from ignition
    By BLOWN93LX in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2009, 02:04 PM
  5. Help IGNITION KEY PROBLEM
    By cool50 in forum General Tech Discussion
    Last Post: 02-28-2009, 11:57 PM
