Thread: Motor Oil Leak!
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 76
  1. #1 Motor Oil Leak!
    SE Level Member TMOTA503's Avatar
    Feb 2008
    503, OR.
    SUX !!!! :[
    Me and a cousin lifted it up and there were three bolts that were completly covered with oil and before thet i turned it on and all the oil just splattered out.
    wondeing if there might be a commen thing or ????? yeah
    my guess might be those bolts or if not the gasket.
    im going to raise it up for today, first gotta remove the front bumper, my jack is a mini jack lol to small for a powerful GP GT lol
    well please help
    thanks
  2. #2 Re: Motor Oil Leak!
    PA
    Where is it leaking from? What bolts?
    2001 GSE
  3. #3 Re: Motor Oil Leak!
    Feb 2008
    503, OR.
    im not really sure... i just was able to put it up on the ramp and its only when u steup on it/ rev its when it drips lots
    butits near the .... uhhh cant remember the name. its on like on the passengers side
    my counsin is coming and know more so ill just u load some pix ok
  4. #4 Re: Motor Oil Leak!
    Feb 2008
    503, OR.
    OK its right next to the belts or right undeer it. looks like a oil pan. those bolts and everything around der is covered with oil and guess thats were the problem is.
    see no ordinary oil spill
    <a href="http://s208.photobucket.com/albums/bb80/TMota503/?action=view&current=c173385419dd.jpg" target="_blank"><img src="http://i208.photobucket.com/albums/bb80/TMota503/c173385419dd.jpg" border="0" alt="Photobucket"></a>
  5. #5 Re: Motor Oil Leak!
    Feb 2008
    503, OR.
  6. #6 Re: Motor Oil Leak!
    Feb 2008
    503, OR.
    well its up now....
    and the leak is coming from one hose on top of this thingy lol
    sorry i dont know much about cars
    and kind of a hose but with bolts and like a steal piece not aluminum
  7. #7 Re: Motor Oil Leak!
    I live here. UR LOSN's Avatar
    Rockford, IL
    the only lines that are on the passenger side are the Power Steering lines.
    are you sure it is coming from a hose? or maybe something dripping onto the hose?
    I think your oil pressure sending unit is right there...it may have a crack..... IF it is not coming from a hose...
  8. #8 Re: Motor Oil Leak!
    PA
    Next question. What engine does this car have in it? I see that you started this thread in the 3.1L section. But I assumed that the GT had a 3800 in it?
    What engine does your car have?
    2001 GSE
  9. #9 Re: Motor Oil Leak!
    Feb 2008
    503, OR.
    its the steal hose for sure. and i yeah i saw the power steering lines but those ar on the way bottom arent they?
    this bronze color steal hose is connected with bolts and what not.
    and yeah its a GT but has a SE front bumper, [head on collision] so its a messed up title.
    i wanna fix it before i sell it. why???? im just a teen and gonna start college classes
    i have to let my first car go fast
    thanks for the help and plz keep on helping
  10. #10 Re: Motor Oil Leak!
    Feb 2008
    503, OR.
    lol i kinda went off subject sorry. yeah im guessing its a 3.1 doesnt look like a 3800 to me.. ill take a pic of engine bay 2moro so you can see.
  11. #11 Re: Motor Oil Leak!
    Rockford, IL
    3.8L have an engine cover, and under the engine cover is a black plastic intake manifold. the 3.1L have a cast Upper intake manifold...and has 3100 on it.
  12. #12 Re: Motor Oil Leak!
    Feb 2008
    503, OR.
    hmmmm doesnt have none of that.
    it was in a head on collision
    nd i guees they took off the 3100...
  13. #13 Re: Motor Oil Leak!
    PA
    Quote Originally Posted by TMOTA503 View Post
    The 3100 is cast right into the intake manifold of the engine. The only way they could remove it is with a grinder and some time.
    Can you take a picture of the engine? If you want help with the leak, we need to know what engine you have.
    2001 GSE
  14. #14 Re: Motor Oil Leak!
    Feb 2008
    503, OR.
    ders a pic of my dirty engine bay
    xD
  15. #15 Re: Motor Oil Leak!
    PA
    That would be a 3800 engine. Not a 3.1.
    2001 GSE
  16. #16 Re: Motor Oil Leak!
    Feb 2008
    503, OR.
    dammm really????
    always thought it was a 3.1
    should i move this thread or just keep it here?
  17. #17 Re: Motor Oil Leak!
    TDCRacing
    Guest
    Post up a better picture of the problem if you can.
  18. #18 Re: Motor Oil Leak!
    Feb 2008
    503, OR.
    ill try cuz i only have my cell fone to take pictures but ill see wat i can do
  19. #19 Re: Motor Oil Leak!
    Rockford, IL
    ok. 3.8L.
    only lines on Passenger side are the power steering. However.....
    have you changed the oil lately? the 3.1L oil filter will not fit correctly on the 3.8? housing. and it will cause it to spray out.
    also another possibility.... the oil filter is double gasketed.... the rubber ring on the top of the oil filter is still stuck to the mount, and then the new filter had one as well. when you put the new filter on with the old rubber ring still on the mount... it will NOT seal, and cause it to spray oil oil.... causing a pretty big puddle....
    then there is the oil pump itself in the front cover, valve cover, oil pan gasket, etc.
    like posted above....a better pictre would help out...
  20. #20 Re: Motor Oil Leak!
    Jul 2008
    sumter,south carolina
    3.8 engines are known for leaking where the oil filter screws into the engine...not sure of the proper name for this part but i hear its a easy fix
  1. vacuum leak
    By boredout in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-15-2008, 08:22 AM
  2. Bad vacuum leak
    By boredout in forum General Tech Discussion
    Last Post: 07-14-2008, 02:21 AM
  3. Coolant leak
    By jdgaetan in forum General Tech Discussion
    Last Post: 05-31-2008, 03:24 AM
  4. Oil leak
    By fiveinthelive in forum General Tech Discussion
    Last Post: 03-11-2008, 09:35 AM
  5. Oil leak problem
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 05:24 AM
