Thread: Bosch IC pump wiring
Results 1 to 13 of 13
  1. #1 Bosch IC pump wiring
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    I bought this pump and stuff used and am riging it all together just wondering what other people have done for a power source fot it
  2. #2 Re: Bosch IC pump wiring
    St. Louis
    My guess would be the battery, but I don't know IC's so...yea.
  3. #3 Re: Bosch IC pump wiring
    Dec 2010
    Ohio
    hmmm
  4. #4 Re: Bosch IC pump wiring
    Taz.. if you go to the fuel inj circuit for power to a relay. Then you have the best of both worlds. As long as the injectors are firing you have power to the pump. Otherwise..if it's ignition only..you want a switch to turn it off when you are loading a tune or sitting still.
    Which leads to the possibility of not turning it back on..which leads you to searching out my flow detector thread.
    Yeah....buddeeee
  5. #5 Re: Bosch IC pump wiring
    Dec 2010
    Ohio
    Ive seen your thread so fuel inj circuit... where the heck do I tap into that
  6. #6 Re: Bosch IC pump wiring
    Depends where you want taht relay to sit. You could put it in your center console or at the FI's.. anywhere you'd like.
  7. #7 Re: Bosch IC pump wiring
    Dec 2010
    Ohio
    well heres were I riged up the pump
  8. #8 Re: Bosch IC pump wiring
    might want to invest in proper tubing.
    or OCD style: stainless + AN fittings
  9. #9 Re: Bosch IC pump wiring
    Well.. ya know I can't see pictures...
  10. #10 Re: Bosch IC pump wiring
    clear garden hose.
    Pump is mounted correctly though. Somewhat gravity primed.
  11. #11 Re: Bosch IC pump wiring
    Dec 2010
    Ohio
    clear garden hose.
    its not clear garden hose lol its clear hose with braiding in it for protection
  12. #12 Re: Bosch IC pump wiring
    Rated for coolant and high temps?
    http://www.goodyearep.com/productsdetail.aspx?id=4834
  13. #13 Re: Bosch IC pump wiring
    Dec 2010
    Ohio
    not super high temps but its rated for 220* or somthing I have some heater hose but not enough for the hole setup I know what your getting at though I looked at it for awhile and was like thats not very hot... looked around they didn't have any better so I said f it
  1. Intercooler relay and pump wiring?
    By Pure2sin in forum General Tech Discussion
    Last Post: 03-29-2015, 02:39 PM
  2. Bosch ABS Schematic wiring AnyOne
    By plarsson in forum General Tech Discussion
    Last Post: 04-28-2011, 08:38 AM
  3. Intercooler Pump Wiring
    By QwikGT in forum General Tech Discussion
    Last Post: 10-31-2008, 08:38 PM
