Thread: 4 O2 Sensor codes?
Results 1 to 8 of 8
  1. #1 4 O2 Sensor codes?
    Oct 2011
    davison
    So for a while my 05 Grand Prix has the check engine light on. Today I went out and had the codes read. I'm getting P0133,P0420,P1133,P1134. I've these problems before and had a shop replace the O2 sensor twice. I'm tired of paying him the same thing every time to have this continue to happen. I want to fix it myself if possible and try and eliminate this problem. I don't know if it matters but the car doesn't get great gas mileage either. Any help is appreciated.
  2. #2 Re: 4 O2 Sensor codes?
    how long ago(miles) did they get changed?
    how long were you driving around with these codes?
    the reason your not getting good gas mileage is because with these codes present your car is running rich because its doesn't know what the sensors are reading it basically goes to a default setting,
    and buy running rich all the time its dumping raw fuel in the exhaust which is very bad for the cat and if the damage is to late then the cat is toast and will have to be replaced but hopefully youll get lucky and yours will be ok
    SMGPFC Member #10
  3. #3 Re: 4 O2 Sensor codes?
    Please write out what each code stands for.
  4. #4 Re: 4 O2 Sensor codes?
    come on bill you should know that,
    thats highschool shop class 101
    SMGPFC Member #10
  5. #5 Re: 4 O2 Sensor codes?
    I never took auto shop.
  6. #6 Re: 4 O2 Sensor codes?
    Feb 2009
    flintnasty MI
    Weird... Default fueling (aka open loop) is actually significantly leaner than closed loop.
    Good thing people provide accurate information on this forum.
  7. #7 Re: 4 O2 Sensor codes?
    Oh...that explains it
    SMGPFC Member #10
  8. #8 Re: 4 O2 Sensor codes?
    i didnt mean that, that was the actually default i just said that to make it simple
    SMGPFC Member #10
  1. Changed o2 sensor and Still throwing out same codes!?????
    By johnnyb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-18-2011, 04:16 PM
  2. Three codes.. what do you think?
    By NaturallySmashed in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-22-2011, 03:32 PM
  3. Best way to change O2 sensor/ECT sensor?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 11-23-2010, 09:36 AM
  4. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  5. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
