Thread: clogged cat
Results 1 to 14 of 14
  1. #1 clogged cat
    Donating Users jrocthakidd's Avatar
    Apr 2011
    Bamberg, Germany
    i have a clogged cat is it possible to still drive the car with a clogged cat? it shakes alot and im just waiting on the parts
    K&N Cold Air Intake, Shortened Dog Bone's, Deleted U Bend, Speed Daddy Headers, Hi Flow Cat, Smaller Head Gasket, Euro Tail Lights, 10" Kenwood's, And MUCH MORE TO COME SOON
  2. #2 Re: clogged cat
    Omaha, NE
    I wouldn't drive it unless you ABSOLUTELY have to. If your o2 sensor decides to lean out your fuel trims, you could end up with major issues.
  3. #3 Re: clogged cat
    SWPA
    Quote Originally Posted by jrocthakidd View Post
    How do you know its a clogged cat? Shaking a lot could have numerous causes. If its stumbling and misfiring then its probably not a clogged cat.
  4. #4 Re: clogged cat
    Omaha, NE
    I agree with this ^
  5. #5 Re: clogged cat
    Jun 2011
    Detroit, MI
    jw, but how much would it cost to have buy a high flow cat and have it installed?
    How 'bout a catted dp?
    iLoveSpade
  6. #6 Re: clogged cat
    Charles City, IA
    Call your local shop they have prices.
    SMGPFC Two Nipple General
  7. #7 Re: clogged cat
    Apr 2011
    Bamberg, Germany
    I had it checked out by a mechanic and I just replace the O2 sensor also cause it was shot!!!
  8. #8 Re: clogged cat
    SWPA
    If it were a clogged cat it would run like you had no power. Just because a mechanic said its a clogged cat, doesn't mean its a clogged cat.
  9. #9 Re: clogged cat
    West Side Michigan
  10. #10 Re: clogged cat
    Yeah I had a clogged cat in my 01GT I got lucky and it was covered by GM.
  11. #11 Re: clogged cat
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
  12. #12 Re: clogged cat
    Jun 2011
    Detroit, MI
    weld in it better because of vibration or something right?
    iLoveSpade
  13. #13 Re: clogged cat
    Apr 2011
    Bamberg, Germany
    it runs with little or no power when i was driving it back. when i cut it on once the was white smoke everywhere (it was also cold)
  14. #14 Re: clogged cat
    Aug 2011
    Maryland
    If you're looking for a high flow cat, i have one you can buy. It's a bolt on, and i only had it on my GP for two months. It has no U-bend, and made a sweet sound. You could hear the increase in flow. I had it coupled with my cat back exhaust. Reason i swapped it out is because the turbo kit i bought came with a cat. If you're interested, i can send you pictures. You can email me at simonmw75@comcast.net
  1. Symptoms like a clogged cat
    By Sig in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2011, 06:30 PM
  2. Possible clogged cat
    By black plague815 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2011, 11:02 AM
  3. Cat clogged
    By wingman65 in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-31-2011, 07:26 AM
  4. figuring out if your cat is clogged
    By imdaman3 in forum How To Write-Ups/Tech Tips
    Last Post: 08-20-2010, 04:52 PM
  5. Clogged cat, bad o2?
    By ninnyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 01:38 PM
