Thread: Oil Pan Replacement??
Results 1 to 10 of 10
  1. #1 Oil Pan Replacement??
    SE Level Member madman1701's Avatar
    Oct 2011
    Fredericton, NB
    Hi everyone,
    I'm new to the forums here. I have tried searching the forums here for a write up on how to replace the oil pan on my GP GT. Any help would be greatly appreciated.
  2. #2 Re: Oil Pan Replacement??
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    You gotta drop the engine cradle or pull the engine for it
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Oil Pan Replacement??
    Oct 2011
    Fredericton, NB
    Sounds like a pain to do then...
    2000 Grand Prix GT (Projector Headlights, 95% Tint)
  4. #4 Re: Oil Pan Replacement??
    whats wrong with the pan you have now? is it rusted, rotted though, or dented? or just leaking from the gasket?
  5. #5 Re: Oil Pan Replacement??
    Ohio
    oil pan.....ughhhh lol
  6. #6 Re: Oil Pan Replacement??
    Oct 2011
    Fredericton, NB
    As far as I can tell from the last time I had it on a hoist, my mechanic said it was pretty rusted and rotting through. I imagine it's leaking from the gasket as well. I have to put about 2qts of oil in a month...I try to do everything I can myself and was wondering if it's a hard job. From what I've researched though I'm better off just paying someone to do it.
  7. #7 Re: Oil Pan Replacement??
    You can do it.. It's just a pain pre 04 as the big motor mount bracket is in the way. An 18mm ratcheting wrench makes pretty easy work of those bolts and you can likely do it by only lowering the subframe slightly for added clearance.
  8. #8 Re: Oil Pan Replacement??
    Ohio
    that bracket needs to come off all the way to get it off, then the 3 bolts that hold it on are in the most pita spots to even finger thread them in. the whole job kicked my ass but it got done. word of advice, start really early in the day on a saturday so you have a full weekend to sit back on. it shouldnt take a whole weekend, you should be done by saturday evening if you take your time
  9. #9 Re: Oil Pan Replacement??
    I live here. TLSheff's Avatar
    I did it at the shop... had to secure the motor with a cross bar, unbolt the mounts, unbolt the craddle, lower it ~3", and could unbolt the pan and slide it out... it IS a pain... but doable
  10. #10 Re: Oil Pan Replacement??
    Ohio
    yeah it is. i honestly think i could have pulled the whole engine quicker than dropping the cradle and all that bull
  1. oil pan replacement
    By frankjc in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-22-2011, 10:29 AM
  2. PCV Replacement
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2010, 03:21 PM
  3. BCM replacement
    By EricGTP in forum General Tech Discussion
    Last Post: 04-28-2010, 07:33 PM
  4. anybody know where i can get a replacement.....?
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2009, 08:46 AM
  5. 6x9 replacement
    By 99gpse in forum Audio, Security & Visual Electronics
    Last Post: 01-31-2009, 07:11 PM
