Thread: Can you spot the difference!?!?
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: Can you spot the difference!?!?
    Antioch, IL
    $18.18 for a replacement pulley from advacned auto. Its steel and not plastic
    2009 Challenger SRT8
    Expert at being gay.
  2. #22 Re: Can you spot the difference!?!?
    Windsor (ON) Canada
    I paid $19, and got a 660 gatorback belt to go with the 3.4, Running smoothly, although my alternator is making a squeaking sound now. FML.
    ps....i just re-used the little black thing I have circeled on the other page, went to the dealership and they had NO idea what it was, it didnt even show up on their enigne picture (therefore, no part #) Pretty sure I didn't even have to put it back on anyways, I did just to be "safe"
  3. #23 Re: Can you spot the difference!?!?
    michigan
    Update, my rattling turns on and off. Sometimes if I turn the heat on it comes on...heat off, turns off. Im stumped.....
  4. #24 Re: Can you spot the difference!?!?
    Antioch, IL
    I think the little black thing is just the spacer/bushing because the pulley doesnt sit 100% on the shaft so it fills in the void....
  5. #25 Re: Can you spot the difference!?!?
    Quote Originally Posted by twol8uluz View Post
    check to see if your a/c compressor is kicking on when you turn the heat on, mine does, so in the winter i pull the relay for the a/c in the fuse box under the hood, no sense it running the ac compressor in the winter in my eyes.
  1. massive flat spot into third WOT
    By redynscire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2011, 09:24 PM
  2. Coolant leak spot found whats the fix
    By davhamm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2011, 12:06 PM
  3. Spot paint jobs?
    By Edagimo in forum Visual/Body Modifications
    Last Post: 09-28-2010, 09:46 PM
  4. Can you spot the 'Wootage'?
    Last Post: 05-05-2008, 08:00 PM
  5. Can you spot my new appearance mod?
    By DuBob in forum Visual/Body Modifications
    Last Post: 04-10-2008, 09:04 AM
