Thread: Headers! NEED HELP PLEASE
Results 21 to 40 of 44
  1. #21 Re: Headers! NEED HELP PLEASE
    GTP Level Member 2001goldGTP's Avatar
    california
    Yeah I only had to do it once and I didn't have to bend the dipstick I guess I just got lucky
    xp'd
  2. #22 Re: Headers! NEED HELP PLEASE
    Sep 2011
    Omaha
    Just asked for help not to get bagged on by my decision.
    I think the TOGS will be a great buy and a lifetime warrenty.....
  3. #23 Re: Headers! NEED HELP PLEASE
    Minnesota
    TOGs are very good headers. Some people on here just base their opinion more on other people than real world experience (actually owning the product). Lots of people on here have a hard-on for Speed Daddy headers. The thing is to make them "Right" you would still have to have the downpipe re-welded. For the price that might not be that big of an issue for some people.
    There are a few tips for installing them such as buying washers to install when you put the donut gaskets on both sides of the crossover. You should also put copper RTV around the donut gasket after you install the cross over to help it seal. You can also get a pre-bent dipstick from someone selling a few of them in the classified section. Other than that I have had no issues. The install is not that hard if you have the right tools and your not an idiot.
    Some others will tell you that because the upstream O2 is too close to the bottom of rear header that you will have issues with fouling out O2 sensors all the time with TOGs. I have not run into this issue and run my car pretty well.
    Good luck with the install.
  4. #24 Re: Headers! NEED HELP PLEASE
    Quote Originally Posted by 2001goldGTP View Post
    A tog install w/o bending the dipstick or swapping it for a prebent. I'm calling BS. Smelly big ole pile of BS, that is.
    Togs aren't a bad install. The only part I dislike is the rear crossover hookup. It's close to the trans and tube, pretty much requires a second guy to install it.
  5. #25 Re: Headers! NEED HELP PLEASE
    california
    well roll around in the bs then . i went on the look for a pre bent dip stick, then someone told me that its just an 04+ dipstick.
    I took the stocker out installed the rear header, put the dip stick back in and it went in fine and sealed right up, It has only been this way for a year now.
    I know that you have installed a lot of headers, and like i said i must have been lucky or something. But to throw out the for this strikes me as odd. I didn't say that i did the install in like 5 mins and i didn't say that after the install i went out and ran 12s lol.
    I did not buy another one because i never found one before i did the install and i did not bend mine because i knew with my luck i would pinch it off.
    xp'd
  6. #26 Re: Headers! NEED HELP PLEASE
    Your install time was pretty quick. Then to say you didn't swap the tube. Meaning a 97-03 tube fit with the headres. That's against everything I've seen and against even the vendor websites.
    Not to say you don't have a newer tube or something, but yea..I called bs on it being a stocker tube and that they went go on in 3-4 hours taking your time. Most guys will spend all day at it. Fight the rear cross over bolts (takes two guys for most newbie TOG installs). It takes guys that do them all the time 3-6 hours depending. I'm all for saying it's easy and everyone can do it, but your info was a little suspicious.
  7. #27 Re: Headers! NEED HELP PLEASE
    california
    ok you are right i should have said that about 8 months before the TOGs i put in PEMs, and i dont have the rust issues most have because i live in cali and get no snow at all and my car to this day only has 84K on the clock.
    The dip stick in this car is the dipstick it came with when i bought it, and i bought it bone stock from a stealership, the damn thing still has the factory head unit lol
    xp'd
  8. #28 Re: Headers! NEED HELP PLEASE
    Pennsylvania
    Quote Originally Posted by Akuch26 View Post
    The quality is great. I'm not sure how a lifetime warranty works for a company that no longer exists, though.
    Quote Originally Posted by Pure2sin View Post
    You need to do downpipe work with TOGs, too.
    I didn't bother with this (though I considered it), as the donut gaskets crush - No leaks.
    Perhaps I exaggerate too much on how much of a pain that was to do... I definitely needed a second person.
  9. #29 Re: Headers! NEED HELP PLEASE
    Quote Originally Posted by SlowNA06 View Post
    You didn't. I'm a seasoned installer and still needed a second person.
  10. #30 Re: Headers! NEED HELP PLEASE
    Sep 2011
    Omaha
    Well its all good cuz I'm taking it to a shop to get them installed...cuz I don't have the time to do it as of right now.
  11. #31 Re: Headers! NEED HELP PLEASE
    Bring them the Easy Method of installing headers that I wrote up. It'll cost you much less.
  12. #32 Re: Headers! NEED HELP PLEASE
    Pennsylvania
    Ah, to have a lift. I think I spent a total of like 7 hours laying on my back under the car, lol
  13. #33 Re: Headers! NEED HELP PLEASE
    Did you fall asleep?
  14. #34 Re: Headers! NEED HELP PLEASE
    Pennsylvania
    At one point, maybe, yeah. Installed the rear manifold twice. Downpipe rust-welded itself to catback. funfunfunfun
  15. #35 Re: Headers! NEED HELP PLEASE
    Sep 2011
    Omaha
    Haha...easy method? didn't know there was an easy method of installing headers? lol
    i'll have to look back at it but thank you
    anyone here ever ported the supercharger in the 04's? is it a good gain for the $? and how much is it?
  16. #36 Re: Headers! NEED HELP PLEASE
    Sep 2011
    Omaha
    And i thought the 04 gtp's didnt have to worry about the dipstick?
  17. #37 Re: Headers! NEED HELP PLEASE
    Sep 2011
    Omaha
    and Bill where can i find your easy method?
  18. #38 Re: Headers! NEED HELP PLEASE
    Pennsylvania
    Zero gains. Costs nothing, because you won't do it. The end.
  19. #39 Re: Headers! NEED HELP PLEASE
    Sep 2011
    Omaha
    What about the dipstick?
    Thought the 04's didn't have to worry about that? or did i think wrong?
    I've heard about great stuff from porting the sc? it won't gain anything?
  20. #40 Re: Headers! NEED HELP PLEASE
    Minnesota
    Donut gaskets crush? Since when?
  1. Just Put in my set of SLP HEADERS but....
    By 9ordohz in forum General Tech Discussion
    Last Post: 03-11-2011, 04:04 PM
  2. first day new headers
    By mousemonster1232 in forum General Tech Discussion
    Last Post: 02-10-2011, 05:04 PM
  3. headers
    By dmoney01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2009, 05:18 PM
  4. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
