Thread: Misfire?!
Results 1 to 14 of 14
  1. #1 Re: Misfire?!
    ^^That guy is right.
    We can't tell you anything unless you tell us what codes you have.
    Because a misfire could be anything...from a bad plug, to a bad wire or a crossed wire...to a gummed up coil terminal not making a good connection, to a vacuum leak somewhere...or coolant puking into the engine, WCS that is...
  2. #2 Re: Misfire?!
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    ok today the SES light never came back on or flashed at all. Could it have been the computer resetting itself from the new spark plugs?
  3. #3 Re: Misfire?!
    SE Level Member ibhuff's Avatar
    san diego
    If you disconnected the battery while changing plugs then yes, but some codes are intermittent meaning they can go away when fixed. Did your problem go away?
  1. Misfire?
    By Sabzz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-17-2010, 10:52 PM
  2. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  3. Misfire
    By munkee in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-12-2009, 06:46 PM
  4. #5 Misfire
    By jjbskisail in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-06-2009, 02:36 PM
  5. Misfire like no other
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2008, 10:02 AM
