Thread: Rear Window Just Dropped
Results 1 to 7 of 7
  1. #1 Rear Window Just Dropped
    Donating Users Burgundyman's Avatar
    The rear left window had dropped halfway, while sitting in the parking lot. Brought car home and removed panel. The switch is fine and power flowing nicely. The window will go down but struggle to go back up. In the past, I simply replaced the entire window unit (regulator and motor). Should I just replace the regulator. GM will not sell the regulator alone.
    1998 Grand Prix - GTP
    RED- 4 Door Sedan
  2. #2 Re: Rear Window Just Dropped
    the cable probably got eaten up. you never see a regulator with out the motor, not much anyways. best to just buy the whole set up. ebay has worked for me in the past.
  3. #3 Re: Rear Window Just Dropped
    That's how I repaired the driver side a couple of years ago. Might just as well do the same. Advance and O'reilly both carry these units though I do not know about fit and finish???
    RED- 4 Door Sedan
  4. #4 Re: Rear Window Just Dropped
    Went to O'Reilly and bought the Dorman OE Solutions - Window Regulator
    Part # 741-838 for $111.00. It has lifetime warantee which is better than AC Delco as it has none. Installed nicely and works just fine. Product from Vietnam.
    RED- 4 Door Sedan
  5. #5 Re: Rear Window Just Dropped
    SE Level Member Paul79UF's Avatar
    Florida
    Next time look on eBay. I've bought at least 4 new motor/regulator combos for my GTP. They are usually about $30-40 and work fine.
  6. #6 Re: Rear Window Just Dropped
    I hear ya...I was in a bind and needed to get the car repaired.
    RED- 4 Door Sedan
  7. #7 Re: Rear Window Just Dropped
    One more thing to remember. Pick up some new plastic clips from the dealer for the door panel, which will provide for a tighter fit upon reassembly. The plastic clips are pretty much trashed when you pull the panel out.
    RED- 4 Door Sedan
  1. Tinted my rear window
    By KawaFord in forum Off Topic Discussion
    Last Post: 05-25-2010, 09:06 PM
  2. 1965 Rear Window
    By buckkunz in forum General Tech Discussion
    Last Post: 05-10-2010, 01:56 PM
  3. rear window leak
    By mainecrab in forum General Tech Discussion
    Last Post: 03-06-2010, 04:56 PM
  4. 04 rear window defroster
    By mikev69 in forum General Tech Discussion
    Last Post: 01-23-2010, 08:08 PM
