No..
You can blow a headgasket, blow a piston up, chip a piston, blow a wrist pin, shoot a rod through the block, get rod knock, break the crank, drop a valve, break a valve spring, wipe a cam bearing, break a timing chain.... I can keep going if you wish.
You also probably never meantion that this happened almost 4 years ago...
You humor fails, you know what I was getting at.
I have mentioned when it happened as well.
Many times.
Also, what does the timeframe have to do with anything? Have they changed anything since then? And if so, what have they done to improve anything?
